Go to Post BEING a chairmans team is alot more important then WINNING the chairmans award. - fuzzwaz [more]
  #106   Spotlight this post!
Unread 29-10-2013, 16:42
AKA: Big Al WFFA 2005
FRC #0111 (WildStang)
Re: "The Little Things" - Helpful hints for all
Alan,
Some of the applications of glue I have seen give me nightmares.
Al
WB9UVJ
www.wildstang.org
________________________
  #107   Spotlight this post!
Unread 29-10-2013, 18:56
Siri's Avatar
Siri Siri is offline
Dare greatly
AKA: 1640 coach 2010-2014
no team (Refs & RIs)
Siri has a reputation beyond reputeSiri has a reputation beyond reputeSiri has a reputation beyond reputeSiri has a reputation beyond reputeSiri has a reputation beyond reputeSiri has a reputation beyond reputeSiri has a reputation beyond reputeSiri has a reputation beyond reputeSiri has a reputation beyond reputeSiri has a reputation beyond reputeSiri has a reputation beyond repute
Send a message via ICQ to Siri
Originally Posted by pfreivald View Post
Indeed: use industrial-strength velcro, and a little extra wire. Being able to pull a speed controller (or CRio, or sidecar, or solenoid, or any other electronic component) off of the robot without disconnecting anything, where it can be jimmied/fiddled-with/tightened/etc, is a godsend for fast electronics repair! And it holds up great even under competition impacts--if anything, it helps with shock absorption.
Has anyone ever had problems with velcroing (or wire-tying) electronics like motor controllers? We don't do it, but I've always been sketchy on the explanation.
  #108   Spotlight this post!
Unread 29-10-2013, 19:10
AllenGregoryIV's Avatar
Engineering Coach
AKA: Allen "JAG" Gregory
FRC #3847 (Spectrum)
Originally Posted by Alan Anderson View Post
We're talking about the PWM connector on a Victor here, right? The top of its shroud is nowhere near any circuit boards or components, and the typical practice has been to use less than a pea-sized bit of glue to keep the plug from vibrating. Removing it is trivial if you have a thumbnail. I do not believe there is any danger at all of thermal shock to the board. The only thing that will get remotely warm is the surface of the plastic. It's not like anyone is suggesting using the hot glue to make a watertight connection around the entire connector.
That said, it's still glue, and gluing a speed controller has been explicitly forbidden by the rules.
I've always consider hot glue to be okay. Similar to the adhesive on velcro is that still allowed? I have also seen teams use clear nail polish to hold PWM cables into speed controllers would that also be illegal?
  #109   Spotlight this post!
Unread 29-10-2013, 20:30
Professional Stat Padder
When cutting or drilling parts that are already on the robot, make sure to protect your electronics from metal shavings and the like.
We have a blanket that we throw over our electronics when necessary, but when possible, we take the part off the robot to machine it first.
(2015-Present)
  #110   Spotlight this post!
Unread 29-10-2013, 21:37
yash101 yash101 is offline
Curiosity | I have too much of it!
AKA: null
yash101 is an unknown quantity at this point
Yes. We think we had some problem with that. "The Little Things" must have been falling in
  #111   Spotlight this post!
Unread 30-10-2013, 00:33
Jacob Bendicksen's Avatar
Jacob Bendicksen Jacob Bendicksen is offline
Figuring out what's next
Jacob Bendicksen has a reputation beyond reputeJacob Bendicksen has a reputation beyond reputeJacob Bendicksen has a reputation beyond reputeJacob Bendicksen has a reputation beyond reputeJacob Bendicksen has a reputation beyond reputeJacob Bendicksen has a reputation beyond reputeJacob Bendicksen has a reputation beyond reputeJacob Bendicksen has a reputation beyond reputeJacob Bendicksen has a reputation beyond reputeJacob Bendicksen has a reputation beyond reputeJacob Bendicksen has a reputation beyond repute
We've been velcroing just about everything on the control board for as long as I can remember, and we haven't had any problems so far. However, don't velcro the main breaker. There isn't enough surface area on the bottom for velcro to effectively hold it in place, and it's too important to have flopping around in there.
As for things that I'd suggest, I've got:
-For Chairman's, always have at least one boy and one girl on the presentation team. Trust me on this one.
-Also for Chairman's, practice the presentation ridiculously slow in front of the entire team. In addition to making you look like fools, it serves a few purposes: giving the presenters practice under pressure, making the presenters used to going slowly, and giving the entire team at least a basic understanding of what the Chairman's submission contains. Which leads into my next one...
-Everyone on the team should be able to talk to the judges about the team's outreach. Without fail, judges always come by when the spokespeople are in the bathroom, so others should be able to cover until they're back.
-In terms of outreach events, I think Karthik said it best when he said that you should find that "pie in the sky" and MAKE IT HAPPEN. That's where amazing Chairman's submissions come from--that crazy idea that worked.
jacobbendicksen.com | @jacobbendicksen
Yale University Class of 2020
Team 1540 | 2012-2016
7 Chairman's Awards, 6 other awards, 2015 Dean's List Finalist, 1 event win, 2 finalist finishes. Thanks for an amazing ride.
  #112   Spotlight this post!
Unread 30-10-2013, 04:41
BBray_T1296's Avatar
I am Dave! Yognaut
AKA: Brian Bray
My take on the Glue vs No Glue debate
Name:	Mount Gluem.jpg
  #113   Spotlight this post!
Unread 30-10-2013, 08:00
My opinion is that the adhesive on velcro is not considered "glue" for this purpose, it fits in the same group as labels. Nail polish on the other hand may be considered more than adhesive backed materials.
We used velcro in the past but abandoned it in favor of tie wraps. They are cheaper, easier to use and just as fast to replace components.
As a side note, the Q&A is the only place to get definitive answers to rules questions. My posts are my interpretation of the rules. I have been wrong before.
Al
WB9UVJ
www.wildstang.org
  #114   Spotlight this post!
Unread 30-10-2013, 08:38
MechEng83's Avatar
MechEng83 MechEng83 is offline
Lead Mentor/Engineer
AKA: Mr. Cool
FRC #1741 (Red Alert)
MechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond repute
Yes. Make sure your whole team knows about your outreach and can speak semi-intelligently about it.
However, I have heard stories from several years-worth of my students at different regionals saying judges have "interviewed" them in the bathrooms - so you should always be prepared to answer questions about your team!
As a corollary, make sure your non-robot students have a basic understanding of your robot's functionality. Our non-engineering captain last year claimed to the judges that everyone on the team was instructed on how the robot functioned even if, like him, they didn't work on it. They called his bluff and made him explain the systems. He did a good job!
2016 INWLA GP| INWCH Entrepreneurship | INPMH DCA | INCMP Team Spirit | CAGE Match Winner (w/ 1747 &868), Finalist (1471 w/ 1529 & 1018), Best Fans
2015 ININD Judges Award, Proud "Phyxed Red Card" alliance partners of 1529 & 1720 | INWLA EI | INCMP GP
2014 Boilermaker Creativity | Chesapeake Finalist, Safety, GP, Entrepreneurship | IN State Championship Winner (w/ 868 & 1018) | CAGE Match Winner (w/ 1024, 5402 & 1646)
2013 Boilermaker RCA, Innovation in Controls, Finalist | Crossroads Entrepreneurship | Newton Semi-finalist
2012 Boilermaker Entrepreneurship | Queen City EI | Curie Semi-finalist
2011 Boilermaker RCA, Entrepreneurship
Red Alert Robotics
  #115   Spotlight this post!
Unread 30-10-2013, 10:48
Jared Russell's Avatar
Taking a year (mostly) off
I can cite many instances of an all-male or all-female presentation team winning a Chairman's Award (at both Regional and World Championship levels).
  #116   Spotlight this post!
Unread 30-10-2013, 11:17
Data Nerd
FRC #0079
Al, how would you feel about using nail polish as a marking to help quickly ID which direction the connector goes in and where? Reason - Nail polish comes in a lot of colors, is pretty cheap, readily available. It COULD be considered adhesive holding the connector in.
(Obviously, if I plan on doing this and there is ambiguity in the rules I will post in Q&A during season. Just trying to get a bearing here)
  #117   Spotlight this post!
Unread 30-10-2013, 11:28
FrankJ's Avatar
FrankJ FrankJ is online now
Robot Mentor
FRC #2974 (WALT)
The trouble is the Q&A often creates more ambiguity than they resolve.
  #118   Spotlight this post!
Unread 30-10-2013, 11:43
Tungrus Tungrus is offline
Tungrus is just really niceTungrus is just really niceTungrus is just really niceTungrus is just really nice
"To Glue or Not To Glue"...as an electrical engineer I don't see any problem using regular hot glue to stick PWM wire to Victor/Talon or any controller. Though I think this is not tampering (no cutting, damaging or enhancing the functionality to take advantage, not a source for safety concern etc.), but the inspector may not have the same opinion. We avoid this situation by using hot glue or electrical tape to secure the wire to the robot frame, a little before it reaches the motor controller. Typically we use velcro to secure the motor controllers and the power wires (both in and out) are secured by zip tie. The motor controllers don't move as much as the loose PWM wires. Then we use electrical tape to fasten the PWM wire to the fan without blocking the air circulation. On the other end, pins on the side car will keep them secured.
  #119   Spotlight this post!
Unread 30-10-2013, 12:02
rees2001 rees2001 is offline
AKA: Rees
FRC #0340 (Greater Rochester Robotics)
rees2001 has a reputation beyond reputerees2001 has a reputation beyond reputerees2001 has a reputation beyond reputerees2001 has a reputation beyond reputerees2001 has a reputation beyond reputerees2001 has a reputation beyond reputerees2001 has a reputation beyond reputerees2001 has a reputation beyond reputerees2001 has a reputation beyond reputerees2001 has a reputation beyond reputerees2001 has a reputation beyond repute
No Glue
  #120   Spotlight this post!
Unread 30-10-2013, 12:48
MechEng83's Avatar
AKA: Mr. Cool
Originally Posted by rees2001 View Post
That is awesome.
Red Alert Robotics
