How did this work out for you? We are building something very similar as our off season project. This style chassis is extremely stiff and has a very low center of gravity so I doubt you had the predicted stability problems nor needed a suspension.
The major difference with ours is we went asymmetric - meaning we put the wheels at a 30deg toe-in instead of standard 60deg. This gives us more usable torque front to back (87% vs swerve) and less lateral (50% vs swerver). 45deg would give 70% vs swerve in all orthogonal directions.
Did you do robot centric or field centric controls? What sensors did you use and would you use them again?
Originally Posted by lynca
