Go to Post I like drifting, but I have to go WRC. Putting a car where it doesn't belong feels right, like combining together drill motors and power window motors and putting them on a big patch of carpet. - Billfred [more]
Unread 31-10-2013, 21:21
Jeffrafa's Avatar
Jeffrafa Jeffrafa is offline
Robotics Addict
AKA: Jeff Lewis
FRC #1425 (Error Code)
Jeffrafa has a brilliant futureJeffrafa has a brilliant futureJeffrafa has a brilliant futureJeffrafa has a brilliant futureJeffrafa has a brilliant futureJeffrafa has a brilliant futureJeffrafa has a brilliant futureJeffrafa has a brilliant futureJeffrafa has a brilliant futureJeffrafa has a brilliant futureJeffrafa has a brilliant future
Re: pic: DiscoBots Nano-killough
Originally Posted by gpetilli View Post
How did this work out for you? We are building something very similar as our off season project. This style chassis is extremely stiff and has a very low center of gravity so I doubt you had the predicted stability problems nor needed a suspension.
Although its an old thread, I thought I would chime in with a little info and our teams experience with a similar kiwi drive this past year.
A 4-wheel Holonomic, as 2587 did in 2011 has similar issues encountered by mecanum when it comes to maintaining contact and similar weight distribution between all 4 wheels. Without equal contact throughout a movement, motion will become unpredictable - this can be mitigated with a decent closed-loop control system using a gyro sensor or other feedback, but you are just trying to overcome an inherent mechanical issue.
The 3 basic factors are the floor flatness, frame stiffness, and (optionally) the use of suspension. obviously 4-wheel mecanum drivetrains are much more common than 4-wheel holonomic, so it is easier to look there for successful platforms. Essentially, most successful mecanum bases have either a flexible frame (like a kitbot C-Base), or they have a stiff frame and some sort of suspension. On very flat fields without any 1/4" lexan to drive on some teams may have mild success with a stiff frame and no suspension, but this is not ideal.
An interesting early 4-wheel holonomic used in FIRST competition is 116's 2005 robot: http://team116.org/our-team/robots/2005-robot/ They did a few unique things, including 82-degree cambered omni-wheels (this accomplished 2 primary things - pushed their contact point right to the edge of the frame for stability, and put more rollers in contact with the ground at a time for a much smoother ride on the older-style AM trick wheels). With dual roller omni's available today the second benefit isn't important, but the 1st one is still pretty cool. They had a pretty stiff welded frame, and I can't tell if they had suspension - but it was a very flat field and I think they at least had an adjustment to make sure all 4 wheels were planar.
Last year we exercised the flexible frame perimiter rules to our advantage, chose to do an omni-directional drive, but side-stepped many of these potential issues by going with a 3-wheel holonomic (sometimes called a kiwi drive). Because you only have 3 points of contact, they are all always touching the ground (remember, 3 points make a plane, and a 3-legged stool will never teter). It was the first time we had built something like that (had experimented with mecanum before), but it was a huge success for us. We attended 2 regionals and championships, ranked 4th in our division and made it to semi-finals (our best CMP showing in our 10-year history). In 44 matches throughout the season, plus another ~25 in off-season events we never once changed wheels, or performed any transmission maintenance - the drive was completely trouble-free.
We definitely didn't play defense much, but with a skilled driver we were pretty good at quickly maneuvering around the field and outrunning/avoiding defense. We used robot-relative control (not field-relative, but our driver had RC experience and a fair amount of drive practice). We only used one gyro, which greatly improved our rotational control, and was pretty simple to implement. If the frame perimeter remains flexible, we have a flat field, and we value maneuverability over pushing power I would say we might likely re-use this drivetrain, but in other situations it might not be ideal (fitting it in 28"x38" may be a pretty big stability sacrifice).
Team 1425 Alumnus and Mentor
I am KF7JDK - What's your callsign?
