Go to Post Making even just one person feel safe and included in FIRST is how we know that we have succeeded. - Mr_Moko [more]
Unread 01-11-2013, 17:17
BBray_T1296's Avatar
I am Dave! Yognaut
AKA: Brian Bray
Re: pic: Team 3266 Sheet Metal Drivetrain
Originally Posted by Oblarg View Post
How are you handling the Colsons on dead axles?
My guess is this
Unread 01-11-2013, 17:41
BurkeHalderman's Avatar
BurkeHalderman BurkeHalderman is offline
Casual Robot Observer
BurkeHalderman has a brilliant futureBurkeHalderman has a brilliant futureBurkeHalderman has a brilliant futureBurkeHalderman has a brilliant futureBurkeHalderman has a brilliant futureBurkeHalderman has a brilliant futureBurkeHalderman has a brilliant futureBurkeHalderman has a brilliant futureBurkeHalderman has a brilliant futureBurkeHalderman has a brilliant futureBurkeHalderman has a brilliant future
Originally Posted by Jared View Post
Looks cool! How are the pulleys attached to the colsons and how thick is the sheet metal?
We are using pulley stock and turning the end down to make our own pulley/hub that will press-fit into the Colson wheel. All the sheet metal is .100" aluminum.
How are you handling the Colsons on dead axles? What size Colsons are you using? What pulleys are you using?
The Colson wheels are the standard 4" diameter, 1.5" width. The pulleys press-fitted into the wheels are 28 tooth, 5mm pitch, GT2 profile pulleys, and the ones on the output shafts are 20 tooth.
You can see here the full wheel assembly with the hub, wheel and 3/8" flanged bearings, and on the right is the pulley hub that is machined from pulley stock.
[2010-2014]: FRC 3266 Robots-R-Us: Founder and Alumni
2010 (5-5-1): Buckeye Regional; Driver
2011 (4-5-0): Buckeye Regional; CORI; CAGE Match; Drivetrain/Manipulator Operator
2012 (7-13-0): Buckeye Regional; Queen City Regional; CAGE Match; BPRC; Drivetrain Operator
2013 (25-15-1): Queen City Regional; Buckeye Regional; Crossroads Regional; CORI; Ohio State Champs; CAGE Match; BPRC; Drivetrain Operator
2014 (21-10-0): Crossroads Regional; Queen City Regional; Designer; Mechanical/Design Mentor
Founding an FRC team as an 8th grader sure wasn't easy, but it was totally worth it.
Get in touch with me:
Personal Facebook
I believe every human has a finite number of heartbeats. I don’t intend to waste any of mine. – Neil Armstrong
Unread 01-11-2013, 17:59
Oblarg Oblarg is offline
AKA: Eli Barnett
Nice, I like that custom pulley design. Slick. No flanges?
Re: pulley stock, where do you buy yours? I bought some recently, and was dismayed at how expensive it is.
"The breakfast of champions!"
Unread 02-11-2013, 06:41
MetalJacket's Avatar
MetalJacket MetalJacket is offline
Has read the 2014 manual
AKA: Jesse Gibson
FRC #2068 (The Metal Jackets)
MetalJacket has a spectacular aura aboutMetalJacket has a spectacular aura aboutMetalJacket has a spectacular aura about
Looks great!
One question for you though - how do you plan to mount bumpers? I have been practicing with sheet metal drive bases (my team plans to use one on a competition robot for the first time this year ) and I like the idea of having the flanges of the outermost panels bent outward but I'm not entirely sure how to mount bumpers securely.
Team Role = !artTeam
2011 - Logomotion
- Virginia Regional : Tournament Semi-Finalist, Gracious Professionalism Award
2012 - Rebound Rumble
- Chesapeake Regional : Tournament Finalist, Gracious Professionalism Award
2013 - Ultimate Ascent
- Virginia Regional : Gracious Professionalism Award
Unread 02-11-2013, 09:45
No flanges?
We buy all our pulleys, pulley stock, and belts from SDP-SI. I agree the pulley stock is really expensive. At $60 for a 200mm bar I questioned if it was worth the cost to make our own hubs. Although the price drops a lot per bar the more you buy, which helps justify spending that kind of money.
I haven't put to much thought into mounting bumpers on this frame since it's just an offseason prototype, but I think what we'll do is something similar to 148's 2011 bumper system; put 1" hex standoffs in the corners and then use a uni-body bumper frame and bolt it to those hex standoffs. I'll CAD this and post a picture of it.
Here is a front view of the bumper frame and hex mount:
Personal Facebook
Unread 03-11-2013, 12:48
Chris Endres Chris Endres is offline
Play hard, Work harder
AKA: Topher
no team (WildStang)
Chris Endres is just really niceChris Endres is just really niceChris Endres is just really niceChris Endres is just really niceChris Endres is just really nice
You loss a bunch of strength when you don't have the belly pan under the CIMs. try to fit the CIMs so the belly pan isn't cut out. Anyways, great job, looks like a good start to a great bot.
2009 FLL Illinois State Champions - iLEGO
2010 FLL Illinois State Champions - iLEGO
2011 FLL Illinois State 3rd Place - iLEGO
2011 FLL Illinois State 1st Ambassador - iLEGO
2013 FRC Milwaukee Regional Champions - WildStang
2016 FRC Midwest Regional Finalists - WildStang
Unread 04-11-2013, 09:50
jeremy callahan's Avatar
jeremy callahan jeremy callahan is offline
FRC #5053
jeremy callahan will become famous soon enough
I'm sorry idk if you already answered this or not i didnt see it if you did. I was wondering what the thickness of the metal was and is all the metal machined or did you get any of it assembled for you? looks awesome to see the finish product!
Unread 04-11-2013, 10:13
All the metal is .100" aluminum and is cut out using a laserjet and then bent on an automatic break, this is done by one of our machining sponsors. Then the students rivet the frame together.
As far as the overall design I owe a lot to the guys from 2168 and 228. Without their generosity and CAD files I wouldn't be anywhere near a production ready sheet metal drivetrain. Also the design for the pulley hubs was originally from 2168's 2013 robot and the weight reduction is heavily influenced from their 2011 base. What can I say I'm a huge fan!
Personal Facebook
Unread 04-11-2013, 11:06
$60 for an entire drives worth of pulleys isn't crazy at all.
Unread 04-11-2013, 11:28
Well it's actually about $230 total for all the pulley stock needed for the drive as we need 4 200mm bars of pulley stock. I only have experience using small belts on manipulators, nothing to this scale before, so i dont know if that price still a reasonable amount to spend on this drive?
Personal Facebook
Unread 04-11-2013, 13:50
mman1506's Avatar
mman1506 mman1506 is offline
Focusing on Combat Robots!
AKA: Marcus Quintilian
no team (WARP7)
If you have a CNC you could mill some GT pulley profiles. But 230$ isn't that much for convenience in the scale of things, you can easily spend that amount on pneumatic tires or mechanums.
2016: FRC 865 Mentor
Unread 04-11-2013, 14:10
For that price, I'd buy these pulleys from AM and bolt them to this hub from WCP.
That's $19 per wheel (plus wheel cost) plus tax and shipping. More importantly, it's zero work.
Unread 04-11-2013, 14:17
This is very similar to 2168's drivetrain this year. Check them out if you can.
I don't think having CIM relief pockets in the belly pan is going to drastically compromise rigidity. Being able to "drop out" the transmission can be really useful. You may want to make the cutouts around that access hole a little less aggressive, and possibly consider an additional cross member if your manipulator won't already serve that purpose. The Andymark Cross Hex stuff that comes with those gearboxes in the kit would be an easy way to add some cross support.
Unread 04-11-2013, 20:27
From searching through the forums and reading all the posts about belt drives it was my understanding the GT2 profile and 9mm wide belts were the preferred setup for a FRC application, while the AM pulleys are HTD pulleys made for 15mm wide belts I would like to use the GT2 9mm belts as their smaller but the AM solution is tempting. Do you think the different profiles would have a noticeable difference?
It is actually heavily influenced from 2168's 2013 drivetrain. The credit for the pulley hub design belongs to them, and the weight reduction was influenced from their 2011 drivetrain. They were nice enough to send me their 2013 CAD and I learned a lot about sheet metal construction from taking it apart and figuring out how it all went together.
And that is the reason I have the pockets in the belly pan, so the gearboxes can be dropped out of the bottom of the frame for easy maintenance. As far as being a little less aggressive do you mean making the pocketing smaller?
Personal Facebook
Unread 04-11-2013, 21:45
AKA: Jesse Gibson
Given that these are the pulleys that came in the 2013 KoP, I think you'll fine . A team that we work with used the KoP chassis this year and had no problems that I can think of at this time with their drive. The added width is a disadvantage if you want things more compact though.
EDIT - I may have misread your post. If you were suggesting using the 9mm belts on the AM pulleys, I am not knowledgeable enough when it comes to belts to say whether the difference in profiles would have a significant effect although my gut feeling would be to avoid mixing profiles.
2011 - Logomotion
