Go to Post I don't remember who said it or what the words are exactly...(I think it was Hopalong Cassidy) Don't say goodbye, just say see you later. - Al Skierkiewicz [more]
Unread 04-11-2013, 11:06
Re: pic: Team 3266 Sheet Metal Drivetrain
Originally Posted by BurkeHalderman View Post
We buy all our pulleys, pulley stock, and belts from SDP-SI. I agree the pulley stock is really expensive. At $60 for a 200mm bar I questioned if it was worth the cost to make our own hubs. Although the price drops a lot per bar the more you buy, which helps justify spending that kind of money.
I haven't put to much thought into mounting bumpers on this frame since it's just an offseason prototype, but I think what we'll do is something similar to 148's 2011 bumper system; put 1" hex standoffs in the corners and then use a uni-body bumper frame and bolt it to those hex standoffs. I'll CAD this and post a picture of it.
Here is a front view of the bumper frame and hex mount:
$60 for an entire drives worth of pulleys isn't crazy at all.
Unread 04-11-2013, 11:28
BurkeHalderman's Avatar
BurkeHalderman BurkeHalderman is offline
Casual Robot Observer
BurkeHalderman has a brilliant futureBurkeHalderman has a brilliant futureBurkeHalderman has a brilliant futureBurkeHalderman has a brilliant futureBurkeHalderman has a brilliant futureBurkeHalderman has a brilliant futureBurkeHalderman has a brilliant futureBurkeHalderman has a brilliant futureBurkeHalderman has a brilliant futureBurkeHalderman has a brilliant futureBurkeHalderman has a brilliant future
Well it's actually about $230 total for all the pulley stock needed for the drive as we need 4 200mm bars of pulley stock. I only have experience using small belts on manipulators, nothing to this scale before, so i dont know if that price still a reasonable amount to spend on this drive?
[2010-2014]: FRC 3266 Robots-R-Us: Founder and Alumni
2010 (5-5-1): Buckeye Regional; Driver
2011 (4-5-0): Buckeye Regional; CORI; CAGE Match; Drivetrain/Manipulator Operator
2012 (7-13-0): Buckeye Regional; Queen City Regional; CAGE Match; BPRC; Drivetrain Operator
2013 (25-15-1): Queen City Regional; Buckeye Regional; Crossroads Regional; CORI; Ohio State Champs; CAGE Match; BPRC; Drivetrain Operator
2014 (21-10-0): Crossroads Regional; Queen City Regional; Designer; Mechanical/Design Mentor
Founding an FRC team as an 8th grader sure wasn't easy, but it was totally worth it.
Get in touch with me:
Personal Facebook
I believe every human has a finite number of heartbeats. I don’t intend to waste any of mine. – Neil Armstrong
Unread 04-11-2013, 13:50
mman1506's Avatar
mman1506 mman1506 is offline
Focusing on Combat Robots!
AKA: Marcus Quintilian
no team (WARP7)
If you have a CNC you could mill some GT pulley profiles. But 230$ isn't that much for convenience in the scale of things, you can easily spend that amount on pneumatic tires or mechanums.
2016: FRC 865 Mentor
Unread 04-11-2013, 14:10
For that price, I'd buy these pulleys from AM and bolt them to this hub from WCP.
That's $19 per wheel (plus wheel cost) plus tax and shipping. More importantly, it's zero work.
Unread 04-11-2013, 14:17
This is very similar to 2168's drivetrain this year. Check them out if you can.
I don't think having CIM relief pockets in the belly pan is going to drastically compromise rigidity. Being able to "drop out" the transmission can be really useful. You may want to make the cutouts around that access hole a little less aggressive, and possibly consider an additional cross member if your manipulator won't already serve that purpose. The Andymark Cross Hex stuff that comes with those gearboxes in the kit would be an easy way to add some cross support.
Unread 04-11-2013, 20:27
From searching through the forums and reading all the posts about belt drives it was my understanding the GT2 profile and 9mm wide belts were the preferred setup for a FRC application, while the AM pulleys are HTD pulleys made for 15mm wide belts I would like to use the GT2 9mm belts as their smaller but the AM solution is tempting. Do you think the different profiles would have a noticeable difference?
It is actually heavily influenced from 2168's 2013 drivetrain. The credit for the pulley hub design belongs to them, and the weight reduction was influenced from their 2011 drivetrain. They were nice enough to send me their 2013 CAD and I learned a lot about sheet metal construction from taking it apart and figuring out how it all went together.
And that is the reason I have the pockets in the belly pan, so the gearboxes can be dropped out of the bottom of the frame for easy maintenance. As far as being a little less aggressive do you mean making the pocketing smaller?
Personal Facebook
Unread 04-11-2013, 21:45
MetalJacket's Avatar
MetalJacket MetalJacket is offline
Has read the 2014 manual
AKA: Jesse Gibson
FRC #2068 (The Metal Jackets)
MetalJacket has a spectacular aura aboutMetalJacket has a spectacular aura aboutMetalJacket has a spectacular aura about
Given that these are the pulleys that came in the 2013 KoP, I think you'll fine . A team that we work with used the KoP chassis this year and had no problems that I can think of at this time with their drive. The added width is a disadvantage if you want things more compact though.
EDIT - I may have misread your post. If you were suggesting using the 9mm belts on the AM pulleys, I am not knowledgeable enough when it comes to belts to say whether the difference in profiles would have a significant effect although my gut feeling would be to avoid mixing profiles.
Team Role = !artTeam
2011 - Logomotion
- Virginia Regional : Tournament Semi-Finalist, Gracious Professionalism Award
2012 - Rebound Rumble
- Chesapeake Regional : Tournament Finalist, Gracious Professionalism Award
2013 - Ultimate Ascent
- Virginia Regional : Gracious Professionalism Award
