Re: pic: The RoboBees' 2015 Control System Alpha Testing Progress
Are referring to the connection port near the center of the roboRIO? If so, it is our understanding that FIRST and NI are leaving that available for teams to further develop. There are extra DIO, PWM, Analog In, etc connections that can be tapped into by teams, if desired.
If you are referring to the D-Sub connector just beside the PD board, that is our sensor connection point for our shooter. We will have back-to-back workshops at VCU on Saturday 23 Nov, if you would like to see the system up close and in person. Last edited by tim-tim : 05-11-2013 at 18:55. |
The green connector is a 50 pin D-Sub connector that we are using as our "quick connect" for sensors between the electronics board and the shooter. We are able to drop the electronics board by removing 4 screws from underneath the robot and disconnecting the D-Sub, a few Anderson PowerPole connections, and a few other wires. Similarly, this gives us the ability to remove the shooter by removing 8 screws, the D-Sub, and a few Andersons.
You can buy them from Mouser Electronics, or plenty of other places in the web. We look forward to seeing you there. |
Here is a link to an article about the roboRIO that a co-worker just sent me
www.nxtbook.com/nxtbooks/hearst/ep1113/#/26 |
-Tim |
I wish we could be a beta-testing team! How'd you guys become one of the beta-testers? But great job! Looks great!
As far as Beta Testing goes, FIRST will send notify teams usually through an email blast for the application process. This year, FIRST sent out this Email Blast requesting all teams interested in participating in 2014 Beta Testing to complete a survey. Again, we are doing Alpha Testing, which to our knowledge did not have a public registration period; Beta Testing is something you must apply for. Thanks for the positive comments. Let me know if you need any further clarification. |
