Go to Post Build a robot that isn't 119.999999 lbs - Peyton Yeung [more]
Unread 07-02-2003, 22:50
CD47-Bot CD47-Bot is offline
FRC #0047 (Chief Delphi)
Image Discuss: 1083 Transmission
FotoPlasma FotoPlasma is offline
FotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond repute
Send a message via AIM to FotoPlasma
One Atwood, one speed...
But how many pounds does that thing weigh?
I played hacky sack with Andy Baker.
2001-2004: Team 258, The Sea Dawgs
2005: Team 1693, The Robo Lobos
Unread 07-02-2003, 23:54
Eric Bareiss's Avatar
Eric Bareiss Eric Bareiss is offline
It's a Bird
AKA: BoogyShoes
FRC #1492 (Team Caution)
Eric Bareiss is a glorious beacon of lightEric Bareiss is a glorious beacon of lightEric Bareiss is a glorious beacon of lightEric Bareiss is a glorious beacon of lightEric Bareiss is a glorious beacon of light
Send a message via AIM to Eric Bareiss
What are you geared at? I see three stages of 1:2
Unread 08-02-2003, 00:24
Benji Benji is offline
Benji is an unknown quantity at this point
Wouldnt it have to have 2 speeds to be a transmission, otherwise wouldnt you call it a gearbox?
Unread 10-02-2003, 10:45
LittleJohn LittleJohn is offline
LittleJohn is an unknown quantity at this point
Post
The box with the Chip installed is 14 lbs (each unfortunately - we are working on it's diet now), and the total gearing on the box from in to out is 16:1. The output shaft turns at 250 RPM at full loaded throttle.
White Paper Discuss: Dual-motor, dual-speed drive transmission design CD47-Bot Extra Discussion 9 03-09-2003 10:40
pic: TechnoKat Transmission 2003 CD47-Bot Robot Showcase 55 23-07-2003 14:41
FYI 'Image Discuss:' is now 'Pic:' Brandon Martus Announcements 0 24-02-2003 12:17
Image Discuss: 1083 Robot Frame CD47-Bot Robot Showcase 6 10-02-2003 10:56
322 Three speed transmission. dkeith Robot Showcase 8 10-06-2002 22:33
