Go to Post free hugs-one size fits all - joshsmithers [more]
Unread 07-02-2003, 17:44
CD47-Bot CD47-Bot is offline
FRC #0047 (Chief Delphi)
Image Discuss: 1024 rookie grabber
GhettoTech GhettoTech is offline
#0300 (Ghetto Techs)
GhettoTech is an unknown quantity at this point
Send a message via AIM to GhettoTech
Wow
You guys are a rookie team? Wow, nice job! Lookin' good :-)
Unread 07-02-2003, 22:02
pauluffel's Avatar
pauluffel pauluffel is offline
AKA: Paul Luffel
FRC #1127 (Lotus Robotics)
pauluffel is a jewel in the roughpauluffel is a jewel in the roughpauluffel is a jewel in the rough
Send a message via AIM to pauluffel
Beautiful robot. I wish we could have done such pretty things last year with Rexroth(tm). The only thing I worry about is if your light is in a legit place. You can see it from all sides, it appears, but I don"t know if enough of it is showing from all sides. Anyhow, because of the glorious Rexroth(R), you can probably change the placement fairly easily.
Unread 07-02-2003, 22:07
wwrye wwrye is offline
#0057 (Leopards)
wwrye is an unknown quantity at this point
pretty beefy, is it under the weight limit?
Unread 08-02-2003, 00:30
Mike Rush's Avatar
Mike Rush Mike Rush is offline
Somewhat Insightful
FRC #4154 (Perpetual Recursion)
Mike Rush is just really niceMike Rush is just really niceMike Rush is just really niceMike Rush is just really niceMike Rush is just really nice
If you have the weight....
Gussetts on the outside of the tubing is reccommended. We have used this material in the past ans under heavy loads (collisions) the webbing has a tendency to break out where the nuts are compressed against the webbing.
We ended up with gussetts about 4" on a side with two connectors in each side of the gussett. THis beefed up the corners enought so we no longer had structural problems.
Just a thought...
Mike Rush - Engineer/Mentor
Perpetual Recursion (4154)
Arizona Community Team (1492)
2004 AZ Regional Woody Flower's Award
Basha High School & Intel (1456)
Gila Monsters (64)
Awards!?! Too many to list...
Unread 08-02-2003, 09:51
Keith Chester's Avatar
Keith Chester Keith Chester is offline
HGFSP
FRC #0025 (Team 25)
Keith Chester is a splendid one to beholdKeith Chester is a splendid one to beholdKeith Chester is a splendid one to beholdKeith Chester is a splendid one to beholdKeith Chester is a splendid one to beholdKeith Chester is a splendid one to behold
Send a message via AIM to Keith Chester
Beautiful robot. Very, very, very good job for a rookie team- especially the arm aspect of it. I expect to see you guys doing good for your rookie year ;-)
A proud graduate of 25.
Students. Teammates. Brothers.
Proud member of R.I.N.O.S., Rookies In Need Of Support.
Unread 08-02-2003, 12:15
LizJJury
so....who are your sponsers...Hmmmm??????
Unread 08-02-2003, 21:33
Michael Long's Avatar
Michael Long Michael Long is offline
FRC #1024 (Kill-a-bytes)
Michael Long is on a distinguished road
Send a message via AIM to Michael Long Send a message via Yahoo to Michael Long
Thanks for the input guys... the arm looks nice but we are having some problems with applying the needed torque to get it all the way around... initially i geared both the cim together... that wasnt enough... then the van door alone... that wasnt enough either..getting frustrated....looks like we are just going to lift it with pneumatics ... cant go all the way over... but at least it will move...... any suggestions??
P.S..... 1024 is a rookie team but i was on team 234 as a senior and worked with them the last few years.... so we are not a "true rookie" as to not miss-lead anyone...
Never Argue with an idiot...
They will drag you down to their level...
and beat you with experience...
Unread 08-02-2003, 21:41
OneAngryDaisy OneAngryDaisy is offline
not on CD enough...
OneAngryDaisy is a glorious beacon of lightOneAngryDaisy is a glorious beacon of lightOneAngryDaisy is a glorious beacon of lightOneAngryDaisy is a glorious beacon of lightOneAngryDaisy is a glorious beacon of lightOneAngryDaisy is a glorious beacon of light
Yeah, the light has to be four inches above your robot- you can lower and raise this for the bar, but it overall has to start and play with a 4 in clearance.. Check the official rules for this-
Unread 08-02-2003, 22:47
Solace's Avatar
Solace Solace is offline
Head Hurts. Coffee. More. Now!
AKA: Jake
#0571 (Team Paragon)
Solace is a splendid one to beholdSolace is a splendid one to beholdSolace is a splendid one to beholdSolace is a splendid one to beholdSolace is a splendid one to beholdSolace is a splendid one to beholdSolace is a splendid one to behold
Send a message via AIM to Solace
actually I think the rule says that four inches need to be visible , nut above the bar. I don't know the specs on that robot, but If you can have 4 inches visible from the other side (the one facing away from the camera), then I think you'll be all right.
...What is a man,
If the chief good and market of his time
Be but to sleep, and tool? A nerd, no more.
2004 UTC New England #2 seed
2004 UTC New England Champions with 716 & 230
2004 Archimedes #2 seed, undeafeated in Qualifiers (for what its worth)
Jake
Team Paragon #571
Unread 08-02-2003, 22:52
not on CD enough...
Team Update 5: PAGE 18, RULE M8,
There have been numerous design questions relative to the installation/placement of the rotating light. The purpose of M8 is to insure that your drivers, the referees, the scorekeeper, and the judges can identify your robot and that the audience has some idea of who’s who; and to make sure that it is installed to enable EASY CHANGEOVER OF THE LIGHT LENSE.
A momentary “loss” of visibility of this beacon is allowable; however, 99% of the time FIRST requires that the top 4” of the light be visible.
The light must be mounted upright, thus it has to be above the bar.. or on the arm, but in that case it'd have to swivel
Unread 08-02-2003, 22:56
Dave Dave is offline
#0654 (Mechateuthis Dux)
Dave is an unknown quantity at this point
Send a message via AIM to Dave
Wood
That doesn't look like wood! I thought rookie teams had to use wood their first year.
Seriously, that's a nice robot. No telling what you'll come up with next year...
I like shiny moving things... perfect!
Unread 08-02-2003, 22:59
Solace's Avatar
AKA: Jake
Re: Wood
yeah, like us! we used wood our first year. And our second year. And our third year.....
...What is a man,
Jake
Team Paragon #571
Unread 09-02-2003, 10:23
Mercutio Mercutio is offline
Atticus Finch Wannabe
#1213 (The Grobots)
Mercutio is on a distinguished road
Treads
Wow, nice tank treads. How's your turning? How many filing cabinets can you pull at one time? ^_^
"If we knew what we were doing, it wouldn't be called research, would it?"
—Albert Einstein
<X3 What can I do? You broke the tie wraps that were holding together my heart. ^_^
Unread 09-02-2003, 11:16
matt111 matt111 is offline
#1024 (McKenzie Kilabytes)
matt111 will become famous soon enough
turnings pretty good it drives like a tank with two joysticks one for each side, but its a little difficult to mauver in our workshop lol
for other info look at this thread
catapults anyone
