Go to Post When you're in a field as deep as the Championship go offensive or go home. It's that simple. - thefro526 [more]
Unread 13-12-2013, 00:06
smistthegreat's Avatar
smistthegreat smistthegreat is online now
robots is a hard job
AKA: Brian Smist
FRC #4930 (The Electric Mayhem)
smistthegreat has a reputation beyond reputesmistthegreat has a reputation beyond reputesmistthegreat has a reputation beyond reputesmistthegreat has a reputation beyond reputesmistthegreat has a reputation beyond reputesmistthegreat has a reputation beyond reputesmistthegreat has a reputation beyond reputesmistthegreat has a reputation beyond reputesmistthegreat has a reputation beyond reputesmistthegreat has a reputation beyond reputesmistthegreat has a reputation beyond repute
pic: Versa Roller Claw
Unread 13-12-2013, 00:07
Andrew Lawrence
Re: pic: Versa Roller Claw
Where was this my rookie year of Logomotion? Awesome design, Brian! I love the usage of the 3.25" versawheels!
Unread 13-12-2013, 00:27
Anupam Goli's Avatar
Anupam Goli Anupam Goli is offline
PCH Q&A co-founder
AKA: noops
FRC #1648 (G3 Robotics)
Team Role: Team Spirit / Cheering
Anupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond repute
Are those extra gussets or motor mounts for the versaplanetary gearboxes?
Team 1002: 2008-2012
Team 1648: 2012-2016
Georgia Tech Class of 2016
RIT Graduate Student, CompE
DampRobot's Avatar
Physics Major
AKA: Roger Romani
Just curious, do you have a reasonable mass measurement for the claw? Nice work by the way, I really like how those end bearing blocks go together.
-Plutarch
Unread 13-12-2013, 00:29
AKA: Brian Smist
@Anupam, they're "VersaFrame VersaPlanetary Side Mount" from VexPro. Just motor mounts, not gussets.
@DampRobot, no idea about mass. Might play around with this more over the weekend.
University at Buffalo | Mechanical Engineering | Class of 2016
2014-20?? | Mentor | 4930 | The Electric Mayhem
2013 | Mentor | 229 | Division by Zero
2013 | Mentor | 4124 | Integration by Parts
2009-2012 | Student | 1507 | Warlocks
Unread 13-12-2013, 00:38
DampRobot's Avatar
Physics Major
AKA: Roger Romani
If you're new to Solidworks, you can find masses by going to the "Evaluate" tab on the ribbon, then "Mass Properties." If, on the other hand, you're like me, an old hand at Solidworks but too lazy to add in the correct materials, I completely understand .
-Plutarch
Unread 13-12-2013, 01:23
AKA: Brian Smist
I'm not new enough to Solidworks that I don't know how to do that, but I am too lazy to put in the correct materials. I might get around to that tomorrow, but then again I should be studying for finals right now. We'll see.
Unread 13-12-2013, 08:42
Seth Mallory Seth Mallory is offline
FRC #0192 (GRT)
Seth Mallory has a reputation beyond reputeSeth Mallory has a reputation beyond reputeSeth Mallory has a reputation beyond reputeSeth Mallory has a reputation beyond reputeSeth Mallory has a reputation beyond reputeSeth Mallory has a reputation beyond reputeSeth Mallory has a reputation beyond reputeSeth Mallory has a reputation beyond reputeSeth Mallory has a reputation beyond reputeSeth Mallory has a reputation beyond reputeSeth Mallory has a reputation beyond repute
Having the motors being the widest parts make then easy to hit. If you want an easy angle gear box get an Harbor Freight 18V angle drill. You then sub in a first motor of the same size, remove the chuck, and then trim or replace the housing.. We used for a grabber a few years ago when 3 days before shipping we decided that what we had could brake off. What we put on did not look nice but it took one day to make and install and it never failed. It was a great gear box. If you look at team 100's bot of a few years ago they had a very nice looking grabber. It also waved to the crowed.
KF6UZX
Unread 13-12-2013, 08:59
Taylor's Avatar
Taylor Taylor is offline
Professor of Thinkology, ThD
AKA: @taylorstem
FRC #3487 (EarthQuakers)
You could also do this.
Hi!
Unread 13-12-2013, 09:07
MrBasse MrBasse is offline
FRC #3572 (Wavelength)
The only issue with that is that it costs $129, whereas the HF Drill is only $35 when not on sale. And when is anything at Harbor Freight not on sale?
Even with quality issues, you can buy 3 of them and find out just how durable they are for less cost. Although I wouldn't go running a CIM through the HF drill...
Andrew Basse
Unread 13-12-2013, 10:40
AKA: Brian Smist
The whole point of this exercise was to examine how easy it is to design a mechanism that used to be custom-only using only COTS parts from VexPro that could be assembled with no more than a drill and a hacksaw. Using the new AndyMark gearbox would be easy to implement, but expensive. Using the Harbor Freight gearbox would be cheaper, but harder to do with only hand tools.
Either way, I don't think my current implementation is particularly bad, especially for how long it took and the fact that it's all COTS. Also, roller claws have definitely been made before, successfully, with exposed motors like this: http://i.imgur.com/PeQIDbJ.jpg
Finally, since I don't plan on actually building this, it's mostly a moot point anyway.
Unread 14-12-2013, 11:56
And the motors are still vulnerable to being broken off....
