Go to Post I've come to the conclusion that the only way Pat's awesomeness can be explained is.... Pat Fairbank is a cookie. - Jonathan Norris [more]
Unread 13-12-2013, 21:15
Alan Ing Alan Ing is offline
None #0368 (Kika Mana)
Alan Ing has a reputation beyond reputeAlan Ing has a reputation beyond reputeAlan Ing has a reputation beyond reputeAlan Ing has a reputation beyond reputeAlan Ing has a reputation beyond reputeAlan Ing has a reputation beyond reputeAlan Ing has a reputation beyond reputeAlan Ing has a reputation beyond reputeAlan Ing has a reputation beyond reputeAlan Ing has a reputation beyond reputeAlan Ing has a reputation beyond repute
Re: pic: FRC228 Tormach CNC Mill
It's an OK machine, considering what it is. It's not going to be the most rigid, precise/accurate, or fastest machine ever, because it's too small, light, and cheap to be all those things, but you should easily be able to produce reasonably good parts to within .005". I do know that Team 368 had some fairly large quality issues with their machine a few years ago, but I think Tormach resolved the issues for them.
Hi All, I'm an engineering mentor with Team 368 (We sat out last year but are back for 2014!). I thought I'd just make some comments regarding the Tormach.
I’m pretty much in agreement with what Cory said about the Tormach. It is not in the same class as a production machine and does not have the mass, rigidity, or power to be compared with machines from Haas, Hurco, Sharp and the numerous other industrial machines. It is however, a great little machine that may fill the needs of many FRC teams who are just getting started in cnc milling.
We bought our Tormach back in 2006 without any real knowledge about how to use it and have been relying on it more and more as the years go by. Accuracy is pretty good, we are usually within .001” and with some care you can get press fits for bearings. I would call the Tormach a proconsumer machine. It’s neither a cheap hobbyist mill nor an industrial machine. It has travels of 18” x 9.5” x 16.25” (xyz) which is not very large but large enough to do many parts that an FRC robot might need. One of the typical things we do is make 25 and 35 pitch sprockets with it. Although the travels are limited, with some creativeness, you can make larger parts by indexing. We cut a 240 tooth 25 pitch sprocket to make a turret that a lunacy ball could pass through back in 2009. There are many accessories including a power draw bar (more like a pneumatic collet closer) and a toolchanger which make it a mini milling center. It is not perfect, but has enabled us to make some pretty cool stuff.
Some things to consider, we have had excellent support from Tormach. As Cory mentioned, we had a quality issue with our mill, but after some discussions and troubleshooting, Tormach made everything right for us and we are happy with its resolution. I believe our problem was just dumb luck and would not hesitate to purchase another mill from them. If you need to know the specifics, you can pm me.
A used industrial cnc machine is a great way to go and you can get some good deals on machines. The only problem is that you should have someone who really know what they are doing prior to pulling the trigger. It is not as simple as plugging in a hobbyist rapid prototyping machine and you may need someone who can troubleshoot, operate, and maintain the machine.
When you buy a used machine, often you are on your own. The Tormach is well documented, has a lot of support and you can get started fairly easy.
Our team is now at the point where we could really take advantage of a larger more powerful machine, but we are constrained by money and space.
Oh, by the way, we use MasterCam, they have a great educational discount, but Tormach also sells affordable cam products too.
