Go to Post Pro-tip: Friends don't let friends play defense! (in qualifications) - Mr. Lim [more]
Unread 16-12-2013, 08:19
rees2001 rees2001 is offline
AKA: Rees
FRC #0340 (Greater Rochester Robotics)
rees2001 has a reputation beyond reputerees2001 has a reputation beyond reputerees2001 has a reputation beyond reputerees2001 has a reputation beyond reputerees2001 has a reputation beyond reputerees2001 has a reputation beyond reputerees2001 has a reputation beyond reputerees2001 has a reputation beyond reputerees2001 has a reputation beyond reputerees2001 has a reputation beyond reputerees2001 has a reputation beyond repute
Re: pic: 18 Tooth #25 Sprockets Inside VersaChassis
Nice looking model.
We have been putting 16T #25 chain inside 2 x 1.5 tube for a couple of years. If you want to do a drop center 16T is as small as you can really go. Your chain will start to stretch and loosen up, rub a bit against the wall of the tube. Assembly of 18T will be almost impossible and if you are just running a 1:1 ratio between wheels why go with an 18T?
I really believe Versa is going to really change things for teams with limited fabrication abilities.
Unread 16-12-2013, 08:45
sdcantrell56's Avatar
AKA: Sean
FRC #2415 (Wired Cats)
Originally Posted by rees2001 View Post
Nice looking model.
The main reason for going with a higher tooth count sprocket is to reduce the load in the chain and increase # of teeth that are meshed. Both influence how robust the system will be.
Mentor 2415
Unread 16-12-2013, 16:14
ajlapp ajlapp is offline
AKA: Anthony Lapp
Two strands of #25 fit side-by-side inside a standard "1x2"x.125" wall tube.
We use 17 tooth double sprockets inside of our SimpleTube Chassis.
You cannot have any drop in this setup because of clearance around the chain.
Otherwise the system is great and is a nice volume save. FRC118 used this same setup for 2013 with zero failures and maintenance issues.
Anthony Lapp
FIRST Engineering Mentor
RobotOpen
anthony@221robotics.com
Twitter us: @221RobotSystems
Unread 17-12-2013, 17:31
Mike Schreiber's Avatar
FRC #0067 (The HOT Team)
How do you get away without any drop? No problems turning?
Mike Schreiber
Unread 17-12-2013, 17:42
They had different diameter wheels. Pretty cool stuff!
