Go to Post FIRST is not all about the robot, it's about the experience. Don't sour yours by whining about it later. - StephLee [more]
Unread 18-12-2013, 19:58
TikiTech's Avatar
TikiTech TikiTech is offline
Mr. H
FRC #3880 (Tiki Techs)
TikiTech is just really niceTikiTech is just really niceTikiTech is just really niceTikiTech is just really niceTikiTech is just really nice
pic: Tiki Techs 2-Speed VexPro Driven WCD
Unread 18-12-2013, 19:59
Andrew Lawrence
Re: pic: Tiki Techs 2-Speed VexPro Driven WCD
If West Coast Drive originated in California, this must be WAY West Coast Drive! Looks awesome! Any particular reason you're using the large wheels and large sprockets? Moving down to a 4" wheel size wouldn't hurt and would save some weight.
Unread 18-12-2013, 20:03
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
The origins of WCD lead back to Arizona initially. Team 60 was the first (that I'm aware of) to do a cantilevered live axle drive.
2001-2004: Team 100
2006-Present: Team 254
Unread 18-12-2013, 20:04
Andrew Lawrence
Learn something new every day.
Unread 18-12-2013, 20:09
R.C.'s Avatar
R.C. R.C. is offline
2017... Oooh Kill em, Swerve!
FRC #1323 (MadTown Robotics)
Neat Render,
If your wanting to do the sprockets on wheel, why not use the smallest VEXpro sprocket that fits?
Also did you guys do the math on the gearing? A 2 CIM Ball Lock @ 6" wheel without a 3rd stage shouldn't work/too fast for FRC.
R.C.
MadTown Robotics Team 1323
Unread 18-12-2013, 20:43
TikiTech's Avatar
Mr. H
Aloha,
Thanks for all the comments. I am still a CAD rookie..
We have many sprocket sizes ordered. My understanding is that the larger the sprocket is, the less working load for a given amount of transmitted power, allowing the use of a smaller pitch chain. We are planning to use #25 chain this year since it is readily available locally at the bike shops. I voted for the three speed transmission personally, but was overruled.
There is still time for a change though...I hope...
This is our first attempt at a non KOP drive train.
Any input on gear ratios, wheels, etc., is highly appreciated..
Mahalo!
Team 3880 - "Tiki Techs" "Mr. H" - Tiki Technologies Coach / Mentor
Kealakehe High School Robotics - Kailua-Kona, Hawaii
__________________________________________________ _____________________________
2016 Division TBD | Orlando Regional Engineering Inspiration Award | Hawaii Regional Chairman's Award & Finalist & Woodie Flowers Finalist
2015 Carson Division | Silicon Valley Regional Engineering Inspiration Award | HI Regional Regional Winners & Engineering Inspiration & Deans List Finalist
2014 Newton Division | Hawaii Regional Engineering Inspiration Award & Deans List Finalist
2013 Newton Division | Inland Empire Regional Regional Chairman's & Creativity Award | Los Angles Regional Engineering Inspiration Award | | HI Regional
2012 Curie Division | Hawaii Regional Engineering Inspiration Award
2011 Newton Division | Hawaii Regional Regional Winners & Industrial Design Award
Unread 18-12-2013, 20:56
tim-tim's Avatar
tim-tim tim-tim is offline
Simplicity by Design...
AKA: Tim Miedzinski
FRC #0836 (The RoboBees)
Where is your Center of Gravity (CG) located? It appears that the CG is relatively centered. You may want to bias the CG to one end of the robot.
Yes, running a larger sprocket reduces the load on the chain; however teams are running down to 16 tooth sprockets for 25 series chain (on 4" wheels I believe). Even running 6" wheels, the sprockets don't need to be nearly the size you have currently selected.
If weight becomes a concern, you can switch out those heavy metal pneumatic cylinders for some lighter plastic ones.
Keep up the good work.
The RoboBees
Unread 18-12-2013, 20:57
R.C.'s Avatar
Originally Posted by TikiTech View Post
Aloha,
Mahalo!
Mr. H,
Awesome! Everyone has to start somewhere. That is true, the larger the sprocket the less working load on the chain. For reference, many teams that do WCD use a 16T-18T sprocket in the 3" to 6" wheel size. Looking at the sprockets available. It would be cheaper and light to use the 32T..
Three speed might be a bit much for your first time around, but either DOG or BALL shifting works well. There is a table on the DOG shifter page that shows output speeds based on wheel size.
With a larger wheel your going to need *MORE* reduction. You want to be somwewhere *4-9* FPS in low gear and *12-18* in high gear.
Hope some of this helps!
R.C.
Unread 18-12-2013, 21:21
42!'s Avatar
42! 42! is offline
College Student
42! is an unknown quantity at this point
As everyone else has said this is a great first start into the world of custom drivetrains. Just two bits of advice. As everyone else said you could go down to a much smaller sprocket size for your outside chain runs. The other is that you need a little more reduction. Judging based on the picture your current speed would be 40 and 17 feet/second. In real life the robot would barely move. However vex does sell a third stage reduction kit for the 2 cim ball shifter. This moves it down to a more reasonable 13 and 6 feet/second at your current setup. IMHO a fairly good speed range for FRC. Just my thoughts, Hope it helps. And for future reference and doing these calcs yourself I would recommend downloading this. http://www.chiefdelphi.com/media/papers/2755
It's the starting point for a lot of FRC drive trains and mechanisms.
Unread 18-12-2013, 21:30
MrBasse MrBasse is offline
FRC #3572 (Wavelength)
...We are planning to use #25 chain this year since it is readily available locally at the bike shops....
Be sure your bike shops actually have #25 chain, most bike shops only carry bicycle chain which is a different pitch. #25 is used on some electric bikes and scooters though so they may have it. If they don't, there is always amazon http://www.amazon.com/gp/aw/d/B004HKITHA
Andrew Basse
Unread 18-12-2013, 22:26
Siri's Avatar
Siri Siri is offline
Dare greatly
AKA: 1640 coach 2010-2014
no team (Refs & RIs)
Siri has a reputation beyond reputeSiri has a reputation beyond reputeSiri has a reputation beyond reputeSiri has a reputation beyond reputeSiri has a reputation beyond reputeSiri has a reputation beyond reputeSiri has a reputation beyond reputeSiri has a reputation beyond reputeSiri has a reputation beyond reputeSiri has a reputation beyond reputeSiri has a reputation beyond repute
Send a message via ICQ to Siri
Moving on from the sprockets*, I like the belly layout. It's obvious you've put a lot of thought into it, which is always good! A few little things:
- It's hard to tell from the iso how much room you have in between the Talons and the DS, but think about wire runs. I'd advocate for routing each controller's power wires paired along the belly pan, but space might get tight. Running to the compressor switch will also be a bit of a haul. (Not suggesting any design change there; just think about your desired route. You might consider moving the spike.)
- Can anyone report good competition success with mounting the D-Link so close to/inset within metal? We try to keep it as far away as possible with clear line-of-sight. If something like this works, it's a really nice design constraint to avoid! Seems like a secure location otherwise.
- In addition to chain clearance (OD sprocket+chain vs. OD wheel), keep an eye on your wheel-bumper clearance. You don't need too much, and of course increasing it shrinks the usable drive base, but I've seen people design way too small a gap. I can't tell what yours is from the iso, but remember that bumpers can flex a bit, and they make really bad brake pads for running wheels.
- Vertical batteries are definitely convenient, and from here the box looks pretty stable, but don't underestimate the moment arm of a vertical battery. At the least, I'd keep in mind having continued access to tighten those flaps' bolts. Around the ~40 match mark of being routinely T-boned, the box may start getting a little upset.
- An even more minor nit pick: I can't tell the distance between the air tanks and the frame rail, but you might want to use elbow connectors on the outside plugs so you don't have to worry about where the tubing loop is while it's so close to the DT chain.
Unread 19-12-2013, 00:29
KrazyCarl92's Avatar
KrazyCarl92 KrazyCarl92 is online now
AKA: Carl Springli
FRC #5811 (The BONDS)(EWCP)
KrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond repute
<R29>
BUMPERS must be supported by the structure/frame of the ROBOT (see Figure 4-6). To be considered supported:
A. a minimum of 1 in. at each end of the BUMPER must be backed by the FRAME PERIMETER,
B. the gap between the backing material and the frame must not be greater than ¼ in., and
C. no section of BUMPER greater than 8 in. may be unsupported.
It looks like you may run into trouble here. If you have one bumper on each side, then there is no frame material to support the bumpers along the wheels at their ends for at least 1 inch (part A).
If you have bumpers that are contiguous around the corners of the robot, then with 6 inches of wheel and what looks to be at least 2 inches between the corner of the frame perimeter and the next backing along the front/back rails, then you're at the very least cutting it very close on the 8 in. unsupported (part C).
[2016-present] FRC 5811 - BONDS Robotics
[2010-2015] FRC 0020 - The Rocketeers
Unread 19-12-2013, 01:18
Joey Milia's Avatar
Joey Milia Joey Milia is online now
FRC #0192 (GRT)
Your placement of the chain sprockets on the outside of the frame should allow you to simplify your axle set up in ways that most WCDs can't do. By bolting the sprocket directly to the wheel there is no longer any need for the axle to be live. This means that you can have the bearings only in the wheels and eliminate the bearings in the frame. It also means that you can replace the hex shaft with a round shaft possibly simplifying machining and allowing you to use cheaper bearings. You should still have the blocks to move the axles, allowing the chain to be tensioned.
These simplifications would only apply to the outside wheels, the center wheels should still be driven by the hex shaft from the gearbox.
Unread 19-12-2013, 05:50
waialua359's Avatar
waialua359 waialua359 is offline
AKA: Glenn
FRC #0359 (Hawaiian Kids)
waialua359 has a reputation beyond reputewaialua359 has a reputation beyond reputewaialua359 has a reputation beyond reputewaialua359 has a reputation beyond reputewaialua359 has a reputation beyond reputewaialua359 has a reputation beyond reputewaialua359 has a reputation beyond reputewaialua359 has a reputation beyond reputewaialua359 has a reputation beyond reputewaialua359 has a reputation beyond reputewaialua359 has a reputation beyond repute
Mr. H,
Charts like these are about the only thing I look at when deciding what ratios we use. Someone else did the math.....we trust the info shown.
2016 Hawaii Regional #1 seed, IDesign, Safety Award
2016 NY Tech Valley Regional Champions, #1 seed, Innovation in Controls Award
2016 Lake Superior Regional Champions, #1 seed, Quality Award, Dean's List
2015 FRC Worlds-Carver Division Champions
2015 Hawaii Regional Champions, #1 seed.
2015 Australia Regional Champions, #2 seed, Engineering Excellence Award
2015 Inland Empire Regional Champions, #1 seed, Industrial Design Award
2014 OZARK Mountain Brawl Champions, #1 seed.
2014 Hawaii Regional Champions, #1 seed, UL Safety Award
2014 Dallas Regional Champions, #1 seed, Engineering Excellence Award
2014 Northern Lights Regional Champions, #1 seed, Entrepreneurship Award
2013 Championship Dean's List Winner
2013 Utah Regional Champion, #1 seed, KP&B Award, Deans List
2013 Boilermaker Regional Champion, #1 seed, Motorola Quality Award
2012 Lone Star Regional Champion, #1 seed, Motorola Quality Award
2012 Hawaii Regional Champions #1 seed, Motorola Quality Award
Unread 19-12-2013, 05:52
waialua359's Avatar
AKA: Glenn
Second this.
We've used bicycle chain every year since 2007. Our old mentor used to custom make our sprockets even after he left and joined another team. We now have our main machinist do them with our students.
