Go to Post New mentor joins one team and ends up impacting several in the same region. I like that. :) - Travis Hoffman [more]
Thread Tools Rating: Thread Rating: 8 votes, 5.00 average. Display Modes
Unread 28-12-2013, 18:37
z_beeblebrox's Avatar
Custom User Title
AKA: Cal
FRC #4183 (Bit Buckets)
Re: pic: Swerve Design
Originally Posted by cmrnpizzo14 View Post
That looks light, how much should it weigh?
Solidworks estimates 36lbs, which seems pretty reasonable.
The top and bottom plates and the module sides are .25" aluminum. Would any pocketing on those be useful?
Unread 28-12-2013, 18:52
theCADguy's Avatar
theCADguy theCADguy is offline
Design Team Student Leader
AKA: Sean Gibbons
FRC #0020 (The Rocketeers)
theCADguy has a spectacular aura abouttheCADguy has a spectacular aura about
Awesome design! Nice work.
Here is a similar design by 221 Robotic Systems. It's a customizable research platform, and has an interesting setup. Steering is accomplished using one motor to rotate two swerve modules. Another motor rotates the rear swerve modules. It seems as if the modules can be turned more than 360°, as the CIMs driving the wheels are located on the center of the drive train, and connect to the modules using a sprocket and chain.
http://www.team221.com/viewproduct.php?id=128
It seem very similar to your design.
Unread 28-12-2013, 19:00
Custom User Title
AKA: Cal
221's module design was one of the things we looked at while designing ours.
Unread 28-12-2013, 19:05
magnets's Avatar
magnets magnets is offline
If you've got machining resources (you probably do if you're going with swerve), then it's probably worth it to pocket the plates. 0.25" aluminum is really strong, so you can make big pockets.
A few ideas for weight savings
You can shrink the module plate by making the whole thing a big triangle and pocketing the center, like this. Your current design looks like you're making them wider so you can add the little support thing. You shouldn't need one because the lower axle with the wheel on it will make the thing stiff enough.
The big green plates mounted to the frame could also get smaller by making them curved, and you could probably mount the steering motor directly to the frame, with no need to make the green plates go out that far.
The idea for using the bike parts for the bearing is really neat.
Unread 28-12-2013, 21:58
Custom User Title
AKA: Cal
Based on the suggestions given, I've made some changes to the design. I've removed the spacers from the module and added pockets. I also mounted the steering motor to the frame rails and reduced the size of the gearbox plates to what was actually needed. It's now about 38.5lbs. (For comparison, the 2013 KOP chassis with 4 CIMs weighs about 32.)
I also noticed that the first iteration was several pounds too light; I hadn't counted the correct mass for the the motors and gearboxes.
Edit: I added some pocketing to the gearbox plates and took off another .5lbs.
Unread 29-12-2013, 16:57
yash101 yash101 is offline
Curiosity | I have too much of it!
AKA: null
yash101 is an unknown quantity at this point
Talking Re: pic: Swerve Design
That is quite lightweight! If you want to get even lighter, I notice that there is some material that won't necessarily add any structural value, so there are many places to drill holes at to reduce weight! Hopefully you use this in 2014 so I get to check it out at the competitions!
Unread 29-12-2013, 17:18
Custom User Title
AKA: Cal
I'm almost certain we won't run a swerve drive in 2014. It's heavy and machining and software intensive for little performance gain over a simple 6WD. This season, we want to build a simple, elegant effective robot quickly and have plenty of time to work on the practice robot, software and driver practice. It would take our team about a week extra to make a swerve drive, a week we can't afford to lose. We might build a prototype the next off-season, though.
Unread 29-12-2013, 18:23
s_forbes's Avatar
s_forbes s_forbes is offline
anonymous internet person
FRC #0842 (Falcon Robotics)
Depends entirely on the resources at your disposal and the rest of the design of the robot... If the other mechanisms require every ounce of spare weight you can sacrifice, then it would be useful in those cases (our 2013 robot fell into this category - not a fun situation!). If it's not necessary to cut drivetrain material in order to meet the weight limit, I would leave it solid. Make the manipulator light instead.
Weight down low is a good thing. Weight up high is not.
