Go to Post ...your education can be interesting and even fun. If you look a little farther down the path, you WILL "use this crap", and "this crap" can even be cool if you know how to use it. - Chris Hibner [more]
Unread 11-02-2003, 10:41
foursixnine foursixnine is offline
#0469 (Las Guerrillas)
foursixnine is an unknown quantity at this point
Send a message via AIM to foursixnine
Originally posted by Solace
that was last year. the drill motors are a lot more powerful last year
Are you sure about this? I was under the impression the drills this year are much more powerful than those from previous years. Can someone confirm this?
the left and right side , i believe, are run at different gear ratios in order to achieve the same speed. (true, one side is probably a little more powerful than the other, but i don't think that that affected anything much.
In theory having more torque on one side of your drive would hinder straight line acceleration since one side would be accelerating faster than the other provided there wasn't any wheel spin. In other words the robot would have a tendency to turn in one direction when accelerating. I suppose this could be corrected w/ programming but you would be putting yourself at a disadvantage since you would be giving up the power of your stronger motors to match the power of the weaker set.
Image Discuss: TechnoKat Teaser #3 CD47-Bot Robot Showcase 14 07-04-2003 01:09
FYI 'Image Discuss:' is now 'Pic:' Brandon Martus Announcements 0 24-02-2003 12:17
Image Discuss: STUDENTS working on 121 CD47-Bot Robot Showcase 5 19-02-2003 22:46
Image Discuss: Chassis Teaser CD47-Bot Robot Showcase 4 10-02-2003 23:00
Triple Crown Belongs to 121! Rick Off-Season Events 58 16-06-2002 22:47
