Originally Posted by Richard.Varone
I knew the wheel concept would catch on! Are you running belt's in the frame? Also what ratio are you running at?
We are running 15mm HDT belts inside the tube. We have been doing that for a few years now and it works great. Knock on wood, we have never needed to replace a belt, and even if we did, it is a pretty simple and quick process. We are currently running a 6.1 reduction, but we have quite a few options if we decided to change our mind. Next week we will be adding 4" Colson wheels, once our WCP hubs come in.
Originally Posted by ksafin
Gorgeous! What weight does it clock in at w/ current electronics bar battery?
The frame alone weights in at 15 lbs. With the motors, gears, belts, and electronics (minus the battery) we weigh in at a svelte 45 lbs.
