Go to Post For the first time, tears of joy came to my eyes when I realized how much I love FIRST. - Arefin Bari [more]
Unread 16-01-2014, 18:01
epylko epylko is offline
Mentor!
AKA: Eric Pylko
FRC #3181 (Pittsford Panthers)
Rookie Year: 1970
epylko is an unknown quantity at this point
Cutting corners (on the robot!)
Hi everyone,
Our current frame is about .25" over the frame perimeter limit (R3-A)
We're going to cut two of the corners at 45 degrees which will put us under the 112" perimeter limit.
My question: do those two new 45 degree angles now count as sides? R19 says "If a side is shorter than 8 in., the entire side must be protected by BUMPER" I suppose it is, since the bumper is coming from the sides and front/back.
What do you think? Any precendent of teams doing this to meet the perimeter limit?
Thanks!
-Eric
Unread 16-01-2014, 18:06
AllenGregoryIV's Avatar
Engineering Coach
AKA: Allen "JAG" Gregory
FRC #3847 (Spectrum)
Re: Cutting corners (on the robot!)
Yes they count, also make sure you are able to follow all of the bumper rules with your new frame.
Unread 16-01-2014, 18:12
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
So they need bumpers on these angles. How are we thinking that would work if the corners are really small? I'm thinking 0.5" long or so. Technically you need a piece of 3/4" wood plus noodles, etc. along that length. Except mitering in a 0.5" long piece of plywood there seems pretty difficult...
Unread 16-01-2014, 19:27
Engineering Coach
That's how I currently read R26.
To be considered supported, a minimum of ½ in. at each end of the BUMPER must be backed by the FRAME PERIMETER.
If that's true then if you cut the corners at all you have to have wood, pool Noodle, etc on that cut corner. The Q&A might be good for this or Al might give a ruling as well.
If it's less than a 1/4" away than that would be legal by the rest of R26.
Unread 16-01-2014, 21:00
Mentor!
AKA: Eric Pylko
Rookie Year: 1970
To make the example easy, if you cut a 45 degree angle (you cut off 1" from the front and 1" from the side), the length would be just over 1.4" long.
R26-A says any gap between the backing material and the frame can be no more than 1/4", so clearly something has to go there.
R19 shows the overlap of the noodle on the hexagon-shaped robot, so a vertical pool noodle attached to the new short side shouldn't be an issue.
The bumper backing could be a robust piece of wood instead of plywood. (R21-A), so perhaps you could create the small triangular piece out of solid wood and attach it to one of the existing bumpers.
The suggestion about Q&A is also a good one.
Thanks!
Unread 16-01-2014, 21:29
stricker.josh stricker.josh is offline
FRC #0418
stricker.josh is an unknown quantity at this point
We had to do this last year at a regional. Yes, they count as sides, the easiest thing to do is to just make curved bumpers.
Unread 16-01-2014, 21:54
themccannman's Avatar
themccannman themccannman is offline
registered lurker
AKA: Jake McCann
FRC #0846
themccannman has a reputation beyond reputethemccannman has a reputation beyond reputethemccannman has a reputation beyond reputethemccannman has a reputation beyond reputethemccannman has a reputation beyond reputethemccannman has a reputation beyond reputethemccannman has a reputation beyond reputethemccannman has a reputation beyond reputethemccannman has a reputation beyond reputethemccannman has a reputation beyond reputethemccannman has a reputation beyond repute
You can always just use your original bumper design, it's fine to have small gaps between the frame and the bumpers in the corners.
All posts here are purely my own opinion.
2011-2015: 1678
2015-current: 846
Unread 16-01-2014, 22:14
theawesome1730's Avatar
theawesome1730 theawesome1730 is offline
FRC #1730 (Team Driven)
theawesome1730 will become famous soon enough
We always undersize our frame by a quarter inch to prevent such possibilities. I would thing that although very small they still count as sides and therefor would need fitting bumpers
2015 GKC Engineering Inspiration
2015 Colorado Winners
Unread 17-01-2014, 09:01
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
Such "small gaps" at the end of the bumper segment can be no more than a half inch long.
Unread 17-01-2014, 09:36
excel2474's Avatar
excel2474 excel2474 is offline
AKA: Aaron Stewart
FRC #2474 (Excel)
excel2474 is a jewel in the roughexcel2474 is a jewel in the roughexcel2474 is a jewel in the roughexcel2474 is a jewel in the rough
Originally Posted by epylko View Post
Hi everyone,
Thanks!
-Eric
Just out of curiosity, what were the dimensions you were aiming for? Did you try to do something like 33"x23" and it ended up over? Always plan for your robot to be out of square, so make it just a little less on each side.
"Find some thing you like to do and EXCEL at it with dilligence."
University of Notre Dame- Mechanical Engineering.
Unread 17-01-2014, 09:37
Jon Stratis's Avatar
Electrical/Programming Mentor
FRC #2177 (The Robettes)
Every year teams like to push the limits with sizing... one of the nice things about the old sizing box was that it kept teams from pushing them too much. Of course, that was also the bad thing, as every robot absolutely had to fit inside the box.
Now with the frame perimeter rule introduced last year, it's a lot easier to get people compliant if they're just a little over. For anything up to a 1/4", you don't really need to cut off a corner... simple rounding all of the corners a little bit is usually enough to get you there, which still leaving each corner as something a normal observer would call a corner and not a side.
That said, as an inspector if I had a team show up where they made a clear decision to cut off a corner (to the point where I can easily define two corners and a side where the single corner used to be) to make the size requirement but still treated it as a rectangular robot for the bumpers, I would be a little annoyed. And an annoyed inspector is a thorough inspector!
Also be aware of R26:
BUMPERS must be supported by the structure/frame of the ROBOT (see Figure 4-10). To be considered supported, a minimum of ½ in. at each end of the BUMPER must be backed by the FRAME PERIMETER. Additionally, any gap between the backing material and the frame
Emphasis mine. Clipping the corner of the frame perimeter but still using a right angle for your bumpers would leave at least part of the end of the bumper unsupported, and the way I read the rule support has to exist from the edge of the bumper inwards at least 1/2".
2016: Lake Superior WFFA
Unread 17-01-2014, 15:14
registered lurker
AKA: Jake McCann
FRC #0846
They're only taking off a 1/4" total so I'd guess this shouldn't be an issue for them.
2011-2015: 1678
2015-current: 846
Unread 24-01-2014, 07:26
AKA: Big Al WFFA 2005
FRC #0111 (WildStang)
Eric,
I have to ask what your frame is made of and perhaps you could give us a picture? There may be some other method of meeting the perimeter rule that you have not thought of. You have some very qualified and experienced LRIs answering above and they are speaking from that experience. We want you to play while meeting the rules.
Al
WB9UVJ
www.wildstang.org
________________________
Unread 24-01-2014, 09:21
gpetilli gpetilli is offline
FRC #1559
gpetilli is a name known to allgpetilli is a name known to allgpetilli is a name known to allgpetilli is a name known to allgpetilli is a name known to allgpetilli is a name known to all
sounds like an opportunity to add a steel right angle iron to your bumper to reinforce your bumper. weight goes to the bumper, not the robot and it will fill the gap in the corner.
Unread 24-01-2014, 09:25
cgmv123's Avatar
cgmv123 cgmv123 is offline
FRC RI/FLL Field Manager
AKA: Max Vrany
FRC #1306 (BadgerBOTS)
cgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond repute
Adding weight that can be seen as unnecessary to your bumpers can be a bad idea. You're allowed to put as much weight in the bumpers as is necessary to build them, but no more.
("As is necessary to build them" is a vague statement, but that's essentially what the rule is.)
BadgerBOTS Robotics|@team1306|Facebook: BadgerBOTS
2016 FIRST Championship Tesla Division | 2016 Wisconsin Regional Engineering Inspiration Award
2015 FIRST Championship Carson Division | 2015 Wisconsin Regional Chairman's Award
2013 FIRST Championship Curie Division | 2013 Wisconsin Regional Chairman's Award
2012 FIRST Championship Archimedes Division | 2012 Wisconsin Regional Engineering Inspiration Award, Woodie Flowers Finalist Award (Lead Mentor Ben Senson)
