Go to Post That tetra has personality! - Kevin Thorp [more]
Thread Tools Rating: Thread Rating: 21 votes, 5.00 average. Display Modes
Unread 19-01-2014, 00:55
WileyB-J's Avatar
WileyB-J WileyB-J is offline
4976 Georgetown Rebels
FRC #4976 (Rebels)
WileyB-J will become famous soon enoughWileyB-J will become famous soon enough
Re: pic: Finished side plates w/paint
Originally Posted by roystur44 View Post
I bet that 3/16" alum panel took over 1.5 hour to make each piece and the 1/8" part on the MITS laser was a little under 1 hour. The time to pierce the material for all the small cosmetic holes is considerable. It looks like it weights a lot.
A CNC punch press would take about 3 minutes to produce the side panel. If the material was .060-.080 alum it would take about 10 minutes to laser cut a part.
A well designed sheet metal part with some folds could take a fraction of time to make and a fraction of the cost to produce.
Just some food for thought to keep costs down for teams with new sponsors.
Good advice.
I disclose I am employed as a design engineer for aforementioned company. I actually had all parts nested to the laser due to the reasons you mention. It was the president of my company who decided to switch the outer plates to the AWJ. But who's complaining?
I believe cutting four of the outer plates took roughly 7-8 hours in total. (!)
To cut the four inner plates on the laser took around 1.5 hours.
Outer panels are 2.8 lbs each and the inner panels are 1.7 lbs each.
