pic: Someone tell me what THIS is!
Re: pic: Someone tell me what THIS is!
Its a talon with a blown transistor
Pretty sure that's a Talon that has been burned out...
It looks like a talon, I've seen the how its made on them
I didn't know that was possible...
Talon Flambe'
It's what's for dinner.................... |
Something tells me that the red leads and the black leads went into the wrong spots--the screws are all out of position...
Talon with a blown capacitor. You probably switched the input wires by mistake...
I agree.. Q12 leads (4) appear to have experienced high heat surge i.e. they are discolored.
& is likely one of the 4 bridge FETs (H-bridge power switch between input power & motor load) often the result of a drain-source overvoltage spike "punch thru" which puts the battery across the switch without current limiting.. strange thing is 2nd FET does not appeared to have the same damage - as one is tied to +12 other to ground return (-) The big cap looks fine.. debris on it appears to be adhesive or pealed conformal coating |
#10
Talons have diodes or something on their input leads to protect from people switching the two
#11
I do not believe that is the case.
#12
Its a talon with busted electrolytic capacitor, the ash/grey dry powdery stuff is the leaked and dried liquid.
#13
That is thermal compound. The cap touches the heat sink.
#14
I can confirm that is not the case!
Been, there, done, that, have the magic smoke and a conversation with Mike Copioli, along with some hush money to get a replacement. No freshmen were harmed during the thermal event, or after I realized what they did. . . |
#15
