Go to Post That seems like a pretty cool idea! Who'da thunk o' dat?! :rolleyes: - dlavery [more]
Unread 22-01-2014, 20:00
jwallace15's Avatar
jwallace15 jwallace15 is offline
What am I going to do with my life?
AKA: Wally
FRC #0068 (Truck Town Thunder)
jwallace15 has much to be proud ofjwallace15 has much to be proud ofjwallace15 has much to be proud ofjwallace15 has much to be proud ofjwallace15 has much to be proud ofjwallace15 has much to be proud ofjwallace15 has much to be proud ofjwallace15 has much to be proud ofjwallace15 has much to be proud ofjwallace15 has much to be proud of
Re: pic: Someone tell me what THIS is!
This Talon came off of our 2013 robot. We got in a habit of unplugging the wires to the talons that controlled our climbing arm. I'm not sure the entire story behind it, but the power wires were reconnected with reversed polarity and poof. White smoke in downtown Flint.
J Wallace IV
Truck Town Thunder
Just a college student now.
Unread 22-01-2014, 20:09
brandon.cottrell's Avatar
brandon.cottrell brandon.cottrell is offline
Vice President
FRC #1266 (The Devil Duckies)
brandon.cottrell has much to be proud ofbrandon.cottrell has much to be proud ofbrandon.cottrell has much to be proud ofbrandon.cottrell has much to be proud ofbrandon.cottrell has much to be proud ofbrandon.cottrell has much to be proud ofbrandon.cottrell has much to be proud ofbrandon.cottrell has much to be proud ofbrandon.cottrell has much to be proud of
It's a minature model of a futuristic city!
Unread 22-01-2014, 20:57
BBray_T1296's Avatar
I am Dave! Yognaut
AKA: Brian Bray
In the future, every city will have 4 buildings that look like terminal screws
Unread 31-01-2014, 09:26
heritageorchard heritageorchard is offline
FRC #3623
heritageorchard is an unknown quantity at this point
Has anyone found a keyed connector that can take 12 gauge wire?
My thought was to mount pigtails on the talons and use two different keyed connectors to help prevent this (happened twice to us).
Unread 31-01-2014, 09:56
vhcook's Avatar
vhcook vhcook is offline
Reader of Things
AKA: Victoria
FRC #1939 (Kuh-nig-its)
vhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond repute
You can do this with the small Anderson Powerpoles. If you take a close look at the housings, you'll note that rather than mounting them side by side, you can attach them together with one of the two rotated 90 degrees. If you do that consistently, you've effectively made a keyed connector.
I've generally found that enforcing color coding and having an experienced second set of eyes check wiring before conducting smoke tests is good enough, but it's an option.
Unread 31-01-2014, 10:06
FRC #3623
Thank You. That is exactly what I was looking for.
Unread 31-01-2014, 10:20
Bill_B Bill_B is offline
You cannot not make a difference
FRC #2170
Bill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond repute
Be sure to do a search for powerpoles here for more hints on their use. We have finally managed to get most of our motors and control components involved in using these, but it is still possible to put a ring terminal on the wrong post and/or a bare wire-end into the wrong Wago hole on the PDB. It would help if more attention is paid to color correspondence. Our talons have red tape next to the sides at which red wires should be connected, for instance.
Nature's Fury FLL team 830 - F L eLements
FRC team 2170 - Titanium Tomahawks
