Re: pic: SolidWorks Electrical KOP - Beta
One of our electrical engineers asked if the current layout of the kitbot would produce noise. I'm not certain if the DLink is too close to other NI components.
When the rookies put together our KOP base, they wedged the router between the sheet-metal frame and the battery. Not so good to place your antenna up against 13lbs of lead
I can't be the only one confused about the wire running straight through the 40-amp breakers, can I?
Anyway, I look forward to using SolidWorks Electrical next year. It seemed like a bit too much to learn in too little time for this year. |
Looks awesome! |
This is human error - at least you can see that you got an issue. Marie |
It's important the teams know what the errors are in the current electrical model, so they don't try to wire it "like the picture" and blow the PD board or something.
Here is a list of errors in the wiring in no particular order: -There are two cRIO components, and they are wired together -No power to cRIO -No power to Analog Breakout -Signal Light is not plugged in -All three versions of the ESCs (i.e. all speed controllers) are present, you should choose one set for the model, not have all 3 chosen and visible -No power to DLink (also no power to converter) -Battery bypasses main breaker and feeds into the 12v output on the PD board That's why we beta test! All of that being said, I can't wait to sink my teeth into Electrical, it makes virtual wiring look really nice. |
Thank you TJ for finding these issues. We will take the SolidWorks Electrical KOP down, fix the issues and create a Beta 2 SolidWorks Electrical KOP.
Teams can still download SolidWorks Electrical and review tutorials and the installation process. But we want to do what is right - every one of the control components contains alot of information. We have to make certain they are defined electrically correct - its like making a spec sheet come alive. Thank you for everyone who has provided feedback for beta 1. Marie |
Are there any updates on this? I noticed a little while back the download link was pulled. For a while it said that a Beta 2 was being created, now, there is no mention of it.
#10
I'd be more worried about it being next to the Jaguars and that big hunk of lead (battery).
