Go to Post It definitely looked like a penalty, but in FRC if it looks like a penalty and smells like a penalty, well, unfortunately it might not be. - Basel A [more]
Unread 24-01-2014, 02:10
BBray_T1296's Avatar
I am Dave! Yognaut
AKA: Brian Bray
Re: pic: SolidWorks Electrical KOP - Beta
When the rookies put together our KOP base, they wedged the router between the sheet-metal frame and the battery. Not so good to place your antenna up against 13lbs of lead
Unread 24-01-2014, 14:06
Michael Hill's Avatar
I can't be the only one confused about the wire running straight through the 40-amp breakers, can I?
Anyway, I look forward to using SolidWorks Electrical next year. It seemed like a bit too much to learn in too little time for this year.
Unread 24-01-2014, 14:10
DELurker DELurker is offline
Former Engineering Mentor
AKA: William Lydick
no team (n/a)
DELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant future
Nah. It's blue, so it cannot be a current carrying wire ...
Looks awesome!
With 1370 --
2012 Rutgers District Event Champions with 1676/56
2012 Lenape District Event Finalists with 2191/1691
2013 TCNJ District Event QuarterFinalists with 1143/4750, Gracious Professionalism Award
2013 Bridgewater-Raritan District Event Semi-Finalists with 4285/223
2013 MAR Championship Finalists (Backup) with 222/11/1403; Gracious Professionalism Award
Unread 24-01-2014, 15:23
Nate Laverdure's Avatar
FRC #2363
You noticed that and you didn't notice the missing Anderson Connectors on the battery leads?
Unread 24-01-2014, 18:36
mplanchard mplanchard is offline
Marie Planchard, SolidWorks
mplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond repute
Good catch - usually wires dont do that. That's why its in Beta - needed to put a few more points in to route the wire.
This is human error - at least you can see that you got an issue. Marie
Unread 25-01-2014, 01:23
TJ_Watson's Avatar
TJ_Watson TJ_Watson is offline
RBE/ME undergrad
FRC #0190 (Gompei and the HERD)
TJ_Watson will become famous soon enough
It's important the teams know what the errors are in the current electrical model, so they don't try to wire it "like the picture" and blow the PD board or something.
Here is a list of errors in the wiring in no particular order:
-There are two cRIO components, and they are wired together
-No power to cRIO
-No power to Analog Breakout
-Signal Light is not plugged in
-All three versions of the ESCs (i.e. all speed controllers) are present, you should choose one set for the model, not have all 3 chosen and visible
-No power to DLink (also no power to converter)
-Battery bypasses main breaker and feeds into the 12v output on the PD board
That's why we beta test! All of that being said, I can't wait to sink my teeth into Electrical, it makes virtual wiring look really nice.
Unread 25-01-2014, 10:30
Thank you TJ for finding these issues. We will take the SolidWorks Electrical KOP down, fix the issues and create a Beta 2 SolidWorks Electrical KOP.
Teams can still download SolidWorks Electrical and review tutorials and the installation process.
But we want to do what is right - every one of the control components contains alot of information. We have to make certain they are defined electrically correct - its like making a spec sheet come alive.
Thank you for everyone who has provided feedback for beta 1.
Marie
Unread 27-05-2014, 23:16
baumgartensam's Avatar
baumgartensam baumgartensam is offline
AKA: Sam Baumgarten
FRC #0751 (Barn2Robotics)
baumgartensam will become famous soon enough
Are there any updates on this? I noticed a little while back the download link was pulled. For a while it said that a Beta 2 was being created, now, there is no mention of it.
