Go to Post Sometimes our greatest failures lay the foundations for our greatest success. - =Martin=Taylor= [more]
Unread 24-01-2014, 21:53
apalrd's Avatar
apalrd apalrd is offline
More Torque!
VRC #3333
pic: Battery connector.....
Unread 24-01-2014, 21:54
SenorZ's Avatar
SenorZ SenorZ is offline
Physics Teacher
AKA: Tom Zook
FRC #4276 (Surf City Vikings)
SenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond repute
Re: pic: Battery connector.....
Yowza. I haven't been in FRC too long, but I've never seen a battery cable melt like that.
Unread 24-01-2014, 22:12
m1506m's Avatar
m1506m m1506m is offline
FRC #1506
m1506m is an unknown quantity at this point
I actually see this on the larger versions of these connectors on the fork trucks we drive at work. Not too often, but try getting a battery off a charger when the two connectors melt together.
Unread 24-01-2014, 22:17
kevin.li.rit's Avatar
kevin.li.rit kevin.li.rit is offline
Imaginary Friend
AKA: Kevin Li
FRC #0596 (SciClones)
Team Role: Student
kevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond repute
Send a message via Yahoo to kevin.li.rit
Someone once told me that the 6AWG connectors were only rated for 80Amps...
Kevin Li
596 - Sciclones
1405 - Finney Falcons
2262 - Holliston Panthers
Unread 24-01-2014, 22:34
Michael Hill's Avatar
I once met a rep from Anderson who was amazed and seemed concerned at how many amps we pull through them. So take that for what you will.
apalrd's Avatar
More Torque!
VRC #3333
This connector is the Anderson SB-50. The 50 is for 50 amps.
Anderson makes larger connectors, the SB-120, SB-175, and SB-300. Those are larger connectors, commonly used on electric forklifts and other really big things.
Using #4 wire certainly helped with this, but the SB-50 does not go up to #4 wire so we had to play with it a lot to make it work. It would be nice to use the SB-120 which comes with #4 size crimps.
Kettering Motorsports
Unread 25-01-2014, 12:28
Joe Ross Joe Ross is offline
FRC #0330 (Beachbots)
Rookie Year: 1997
Around 10 years ago, they did an analysis that showed that for the short time that FIRST robots are run, there was enough margin. However, since that time, average current draws have increased significantly, and many more teams are running practice robots for much longer then 2 minutes. Because of that, I hope that in the near future, FIRST will allow a better connector.
Unread 25-01-2014, 13:02
EricVanWyk EricVanWyk is offline
EricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond repute
Send a message via AIM to EricVanWyk
Would you mind if I used the image at the top of this thread in a blog post for Mooshim? We're posting a video on how to measure contact resistance to identify this type of situation before it manifests as shown.
Unread 25-01-2014, 15:57
Dad1279 Dad1279 is offline
FRC #1279 (Cold Fusion)
Was that pre-assembled or did your team fasten the wires?
I've seen students (and mentors) get the connector in the shell upside down/backwards.
Unread 25-01-2014, 17:50
apalrd's Avatar
More Torque!
VRC #3333
Eric: Sure, go ahead, I have 2 pics of this one if you want them.
This particular connector came from the KOP, where it was pre-terminated on the Anderson end and we crimped/dip soldered the other end with a large ring terminal.
We now buy fully terminated cables from AM or CTRE for the batteries, and make our own from #4 wire for the robot. We crimp both ends on a large press crimp, and dip solder the ring ends (not the connector ends) before assembly.
This cable came from the 2012 practice robot which melted 3 connectors. we also melted two on our 2011 comp bot during the off-season. This is the least bad failure of all of those, in two cases the black wire came through the red connector so the copper was showing all the way down the connector.
FIRST should really switch to the next size up connector.
Unread 25-01-2014, 18:37
cgmv123's Avatar
cgmv123 cgmv123 is offline
FRC RI/FLL Field Manager
AKA: Max Vrany
FRC #1306 (BadgerBOTS)
cgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond repute
Especially since the curent rating on the next size up connector matches the size of the robot main breaker.
BadgerBOTS Robotics|@team1306|Facebook: BadgerBOTS
2016 FIRST Championship Tesla Division | 2016 Wisconsin Regional Engineering Inspiration Award
2015 FIRST Championship Carson Division | 2015 Wisconsin Regional Chairman's Award
2013 FIRST Championship Curie Division | 2013 Wisconsin Regional Chairman's Award
2012 FIRST Championship Archimedes Division | 2012 Wisconsin Regional Engineering Inspiration Award, Woodie Flowers Finalist Award (Lead Mentor Ben Senson)
Unread 26-01-2014, 00:39
AKA: Big Al WFFA 2005
FRC #0111 (WildStang)
Andrew,
I would like to examine this connector up close. I may need to disassemble the connector. Any way you can ship this to me? Jim or Ike has my contact info.
What hit me first off in the picture is why the red wire is not melted as the black wire is. They both pass the same amount of current.
Al
WB9UVJ
www.wildstang.org
________________________
Unread 28-01-2014, 15:13
apalrd's Avatar
More Torque!
VRC #3333
Originally Posted by Al Skierkiewicz View Post
Andrew,
Both wires were hot when the connector failure happened.
When this happens, the terminal begins to sink into the plastic connector. As soon as this happens, it rapidly increases in resistance and melts away (at this point, the current drops, so the other wire would not fail).
I have seen both wires fail, it seems random.
While getting battery cable today (several feet of #4 red and black), I saw some #1 high flex battery cable and smiled. Maybe when we go to the SB-120 I'll use it.
Unread 28-01-2014, 18:21
MrBasse MrBasse is offline
FRC #3572 (Wavelength)
I'm suprised that nobody has said anything about the fact that a robot that can do that repeatedly is designed wrong. If you stay within the limits of your supplied hardware you wouldn't have this issue. Nowhere in the rules does it say you have to draw the amperage that you are. Would it make for a slightly les competitive machine? Maybe. Would it reduce the risk of melting connectors and destroying components? Definitely.
It just seems to me the a lower amperage rated connector is something that would result in an engineering challenge. I'm pretty sure that is what most of us are here for.
This seems comparable to someone complaining that their drill press doesn't work very well as a mill...
Andrew Basse
Unread 28-01-2014, 18:31
Nuttyman54's Avatar
Mentor, Tactician
AKA: Evan "Numbers" Morrison
It's a safety issue. In ANY electrical system, you have safety measures designed to prevent this from happening. In our system, that is supposed to be the 120amp main breaker. FIRST has determined that drawing excess of 120amps continuous causes an unsafe condition and requires the robot shut down. What Andrew has shown, and has been repeated on several other robots, is that under certain circumstances the main battery connector fails before the main breaker, thus circumventing the entire safety system as it is designed.
