Re: pic: Did Somebody Say Defense Game?
Oh god. it's back.
Hey! That's almost as many wheels as ours.
Adding wheels doesn't really increase your traction/pushing power, does it? I'm sure that the extra width helps, but not the number.
Adding surface area in contact with the ground (up to a point) increases traction. It doesn't matter if it's through wider wheels, or more wheels. If friction worked just the way the coefficient of friction says it will, then neither width nor number of wheels will affect traction at all. You could have three 0.1" thick wheels, and have the same amount traction, but friction doesn't follow the super simple columbic prediction, especially on carpet.
How long are you going to have in a pushing match with a 6 cim drive before you start popping breakers?
Love it!
This makes me glad we chose 6CIM drive.
That pretty much sums up what I'm expecting. Quote:
The drive system itself is also much closer to our 2007 bot due to the use of gears to drive the wheels, rather than chain, and a very similar gearbox configuration to the drive we had that year. With the exception of a bearing failure in the finals of West Michigan (which we went on to win anyways), there was virtually no reliability issues with the 2007 drive system. Soon, I'm hoping we have it driving next week. Quote:
Apologies for the wall of text, just figured I'd answer all the questions in one go. ![]() |
#10
#11
And if you are worried about the 234 amps on the main breaker, allow me to show you the current graph as per the manufacturer ![]() As you can see, you can draw 200% (240 amps) for 10 seconds minimum, as per the specifications EDIT: link fixed? Last edited by BBray_T1296 : 25-01-2014 at 21:40. Reason: New link? |
#12
Any reason you chose to assemble the 2 gearboxes identically instead of mirror images (which would have made the drive symmetrical)?
#14
We have to pull the panels apart when we install the idler gears anyways, so we may yet change the configuration of the one gearbox, especially since it's not hard to switch. |
#15
Anyways, that pic is a screenshot from this pdf, page 34 you will find our switch. So long as you do stay within the 40amps per motor, you should not need to worry too much about the main |
