Go to Post We draw the line when our students are more affectionate towards the tools rather than eachother. - ksafin [more]
Unread 26-01-2014, 09:37
magnets's Avatar
magnets magnets is offline
Re: pic: Did Somebody Say Defense Game?
Originally Posted by wilsonmw04 View Post
yep, still broken for me. the 40 amp resetting fuses are what scare me. I have never seen a main blow, but the quick resetting 40's popping = a bad day with robots.
I agree on the 40 amp breakers. Once those things heat up, they're really prone to tripping.
With 6 full size CIMs on drive, you can trip the main doing full forward to full reverse. It's scary to think it could happen in a competition. Also, once you've driven for a minute or so, you can get the battery voltage low enough to cause the radio to drop out. Those CIMs can draw 100 amps at stall. It'll take a few seconds for the 40 amps to start tripping, but the 120 amp breaker trips quickly when you try to put 600 amps through it....
Unread 26-01-2014, 11:19
FRC #1836 (MilkenKnights)
We ran a 6 motor, 2" wide wheel 6WD last year. We had troubles popping the main breaker but not the 40A breakers. Because your motors are sharing the load the current is actually LESS per motor. Therefor it is actually HARDER to trip the 40A breakers.
Unread 26-01-2014, 12:17
Deke's Avatar
Deke Deke is offline
no team (No Team)
What do you think the root cause of the high current load was from? Pushing, turning, hard accels?
Unread 26-01-2014, 12:35
The only time we experienced the main breaker popping was when we went from full speed forward to full speed backwards. Adding in a small ramp prevented us from tripping the main again.
Unread 26-01-2014, 13:02
cbale2000's Avatar
AKA: Chris Bale
FRC #0703 (Phoenix)
What you said in your previous post was correct, you need proper gearing to take advantage of your motors.
Hence our use of a 24:1 Low Gear + 4in wheels on this design.
We've already got our programmers working on this exact thing, we've shredded far too many AM toughbox gears in the past to not know better.
Oh, and for those of you that might not have noticed, I did update the OP with some specs.
Unread 26-01-2014, 11:37
dellagd's Avatar
dellagd dellagd is offline
Look for me on the field!
AKA: Griffin D
FRC #2590 (Nemesis) #2607 (The Fighting Robovikings)
dellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond repute
Tripping the 120 amp? Never had that happen... Anyone who has, what caused it (that wasn't a short )? Your drivetrain?
Popping that is quite a scary thought...
Check out some cool personal projects in computers, electronics, and RC vehicles on my blog!
2016 MAR DCMP Engineering Excellence Award
2016 MAR Westtown Innovation in Control Award
2016 MAR Hatboro-Horsham Industrial Design Award
2015 Upper Darby District Winners - Thanks 225 and 4460!
2015 Upper Darby District Industrial Design Award
2015 Hatboro-Horsham District Winners - Thanks 2590 and 5407!
2014 Virginia Regional Winners - Thanks so much 384 and 1610, I will never forget that experience!
2014 Virginia Quality Award
2014 MAR Bridgewater-Raritan Innovation in Control Award
2014 MAR Hatboro-Horsham Gracious Professionalism Award
2013 MAR Bridgewater-Raritan Innovation in Control Award
2012 MAR Lenape Quality Award
