Go to Post Don't worry so much about the wording of the rules but the intent of the rules. - Greg Needel [more]
Unread 01-26-2014, 01:58 PM
Re: pic: 4587 CAD (With a Shooter Mech.)
Originally Posted by Cash4587 View Post
Not at all, before we shoot we plan to open up the jaws all the way (or just enough) with the gearbox mounted on that pivot point. You can see it here:
http://prntscr.com/2mnlyy
The ball will have a straight path out of the shooter other than the two prongs keeping it in the shooter at the bottom.
The arm will also be able to open really wide to catch as well. Logistics of that are still being worked out.
Have you considered a pneumatic cylinder for this articulation? There are a few advantages. The piston provides the roller with greater normal force for intake. Software is also less complex for this motion. We are using a piston that travels from wide open to a bit under the actual resting position of the roller with a ball inside. It saves us a motor, gearbox, speed controller, and a piece of code to debug.
