Go to Post The proper way to advance forward is by bringing the bottom up, not by limiting how high the top can fly. - artdutra04 [more]
Unread 26-01-2014, 18:19
Ian Curtis Ian Curtis is offline
Best Available Data
FRC #1778 (Chill Out!)
Ian Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond repute
Re: pic: Average 2014 Chassis
Originally Posted by Richard Wallace View Post
We measured about 17 Amperes free current using the stock AM gears, and about 10 Amperes free current after replacing with VexPro gears. Gears were well greased for both tests, and the results were repeatable.
AM steel gears appear rougher, while VexPro 7075 gears have smoother finish. Also, VexPro gears are AGMA 11 -- closer tolerances, better fit.
The free current really tells the story, though. Lower friction, less power wasted.
Wow! That is a big difference. For those of us that don't know much about gears/wear-in/etc. would the AndyMark gears improve over time as the surface finish improves? I think I remember someone (971?) ran their gearboxes on a test stand prior to mounting them on their robot and found it wasn't really worth it. A 50% reduction in free current sounds like something that would be worth it though.
CHILL OUT! | Aero Stability & Control Engineer
Adam Savage's Obsessions (TED Talk) (Part 2)
It is much easier to call someone else a genius than admit to yourself that you are lazy. - Dave Gingery
