Go to Post Remember: This is High School Competition. - rich2202 [more]
Unread 26-01-2014, 19:32
Richard Wallace's Avatar
I live for the details.
FRC #3620 (Average Joes)
pic: Bumper Pockets
Unread 26-01-2014, 19:34
MrBasse MrBasse is offline
FRC #3572 (Wavelength)
Re: pic: Bumper Pockets
Are you going to open those up a bit to allow room for fabric? Or do you have way to mount that doesn't involve the fabric wrapping around the plywood?
We got flagged at MSC last year for dadoing all the way top to bottom on our bumpers, it might be worthwhile to think about a reinforcement at the top. We only went through 1 ply maybe 1.5 too. Our plan for this year was to just dado up far enough for the bolt heads to fit, but then we just made them bigger instead.
Andrew Basse
Unread 26-01-2014, 19:40
Thanks for the heads up. Our pockets are blind, not top-to-bottom. They only extend far enough to reach the minor protrusion.
And yes we will need to adjust a bit to fit the fabric -- this is a work in progress.
Richard Wallace
since 2003
Unread 26-01-2014, 19:51
No problem, I loved it when we did those last year. We had ours set to fit so tight we almost didn't need to anchor the bumpers. The only downside was the one time per competition we removed them for inspection. Another thing to think about...Be sure that you can remove them straight up off the robot with no need to angle them if they are a one piece bumper.
Fit looks great, good luck this year, and we'll see you guys on March 27th!
Andrew Basse
Unread 27-01-2014, 07:52
Rosiebotboss's Avatar
Rosiebotboss Rosiebotboss is offline
2015-16 Divisional LRI - Archimedes
AKA: Dana P. Henry
FRC #0839 (Rosie Robotics)
Rosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond repute
Send a message via AIM to Rosiebotboss
Are the bolt heads less than 1/4"?
Co-Founder/Mentor FRC Team 839 / JrFLL Team 137/Rosie Robotics/Agawam HS
Winner NEF District WPI 2016
Regional CA-08 Boston, 12 WPI, Eng'g Excellence, 12-15 UL Safety, 15 Motorola Quality
KPCB Entrepreneurship 04, 05, 06, 07, 10, 11, 13, 14, 15, 16
Rookie All Star and Top Rookie Seed 2002
Paul Harris Fellow, CMP Inspector 05-16, Head LRI NE FIRST JTB 1944-2008 "What did you do with your dash?"
Unread 27-01-2014, 09:00
Wood backing used in FRC bumpers is 3/4" thick, so by looking at the picture I'd say the bolt heads are less than 1/4".
McMaster shows the head height for 1/4-20 x 1" used for chassis assembly as 5/32", and the head height for 3/8-16 x 4" used as axles as 15/64".
So yes, less than 1/4".
Richard Wallace
since 2003
Unread 27-01-2014, 11:10
The complaint that we got wasn't the fact that the gap was greater than 1/4", it was that we compromised the structure of the plywood and didn't have a full 3/4" backer of plywood. We got though when one of my students cited the rule book almost word for word. In my mind it is fine the way they have it and was fine the way we had it, but it got us placed on a "watch list" of some sort. I don't know what exactly that meant, but I guess if our bumpers exploded or otherwise failed structurally then they would have said "I told you so."
Andrew Basse
