Go to Post I believe with every fiber of my being that Engineering is an Art. It is a beautiful, wonderful, delightful art. - Joe Johnson [more]
Unread 27-01-2014, 23:49
s_forbes's Avatar
anonymous internet person
FRC #0842 (Falcon Robotics)
Re: pic: Diamond Wheels after 10 minutes
How much does your current robot weigh? What gear ratio?
A light drivetrain will tend to 'burn out' the wheels on carpet when starting from a stand still or changing direction. This is not so much the case when it's weighed down with mechanisms and bumpers. If you are using a low gear ratio (by which I mean: slow top speed) and lots of power (you mentioned 3 CIM gearboxes) the effect is more noticeable... I suspect that slipping the wheels on carpet would give the accelerated wear you're seeing.
