Go to Post We are customers to FIRST. In that comes expectations. I don't want to hear another, "You should be grateful for everything FIRST does" nonsense when FIRST royally screws up. - MikeDubreuil [more]
Unread 28-01-2014, 15:53
magnets's Avatar
magnets magnets is offline
Re: pic: How 2415 is rolling for 2014
Originally Posted by wireties View Post
Ditto - looks great!
Are you nervous having the cantilevered portion of the shaft longer than is WCD-typical? And now both forces from the wheels and the chain are working on the extended (from the frame) portion of the shaft.
Sorry if this is a silly question - I'm a goofy EE, its all transitors, 1s and 0s to me.
You're absolutely right. This cantilevered shaft is weaker than a normal WCD shaft because it's longer and isn't loaded on both sides. However, I'm pretty sure it's strong enough, especially with no bumps or towers to wreck your frame this year.
Good choice with chains- I think they're better than belts.
Unread 28-01-2014, 22:01
Originally Posted by sdcantrell56 View Post
We ran the calculations. The axles will be perfectly fine.
Chain on the outside is to free up space on the inside of the robot and easier servicing. We have run belt the past 4 years and so far I am much much happier going back to chain, particularly with the versa bearing blocks and cams
What's the length of the slot you made for tensioning the VersaBlock? Just wondering.
Looking really nice!
Unread 28-01-2014, 22:39
Andrew Y.'s Avatar
Andrew Y. Andrew Y. is offline
FunYun
AKA: Andrew Yun
FRC #2415
Andrew Y. has much to be proud ofAndrew Y. has much to be proud ofAndrew Y. has much to be proud ofAndrew Y. has much to be proud ofAndrew Y. has much to be proud ofAndrew Y. has much to be proud ofAndrew Y. has much to be proud ofAndrew Y. has much to be proud ofAndrew Y. has much to be proud of
Sean demanded the chain be cleaned in a ultrasonic bath so his hipster clothes wont get dirty. Its the only reason we ever did belt.
Unread 28-01-2014, 23:01
Data Nerd
FRC #0079
You know, the worst part is I'm not so sure this is a joke.
