Go to Post "It's not a bug, it's an unlisted feature." - Barry Craig [more]
Unread 29-01-2014, 00:40
Leav's Avatar
Leav Leav is offline
Spud Gun Division
AKA: Leav Oz-Ari
FRC #3316 (D-Bug)
Leav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond repute
Send a message via ICQ to Leav Send a message via AIM to Leav Send a message via MSN to Leav
Re: pic: 4242 2014 CAD 1
Originally Posted by apm4242 View Post
We thought about a high goal blocker but couldn't figure out how build one that would collapse to maintain our low CG and wouldn't deflect outside the 6" column while deployed when hit with a ball. We thought double scissor lift would work maybe. If you have any ideas, I'd appreciate it. We thought I'd be too easy to counter in teleop, so it would only be effective in autonomous. Maybe it would work if you placed the bot in the middle of the goalie zone and used the slider on the driver station I/O to tell the robot how far left or right to move to be in the way of a shooter. Anyway, just a thought.
have a 4-5" tube stick up to about 5' (max height). have another tube slide inside that which is a good fit (you could use small platic plates to make sure it slides nicely and use a pully system to deploy it to however high you want... (you can learn from the pink team)
If you'd like to pursue this further feel free to ask any questions!
"We choose to build robots this season and do the other things; Not because they are easy, but because they are hard."
-Paraphrasing JFK
Participated in FIRST as a student: 2005-2006 (But still learning every season!)
Mentor: 2008 - ? (Team 2630 2008-2011, and Team 3316 since 2013)
Engineer: 2011 - ? (B.Sc. and M.Sc. in Mech. Eng. from the Technion IIT)
FIRST Volunteer - 2007 - ? (MC, FTA, FIRST Aid etc.)
