Go to Post FIRST is not a destination, its not the reward, its the slingshot that will launch you from where you are, to where you can be. - KenWittlief [more]
Unread 29-01-2014, 13:39
apm4242 apm4242 is offline
FRC #4242
apm4242 has much to be proud ofapm4242 has much to be proud ofapm4242 has much to be proud ofapm4242 has much to be proud ofapm4242 has much to be proud ofapm4242 has much to be proud ofapm4242 has much to be proud ofapm4242 has much to be proud ofapm4242 has much to be proud ofapm4242 has much to be proud of
Re: pic: 4242 2014 CAD 1
Originally Posted by Ryan Caldwell View Post
If you have the weight to play with, you may want to have your back wall be 60" tall to block all the low to the ground shooters.
Good idea. Might as well add some lightweight height to it. Maybe to assist with catching/loading. Pool noodles may make an appearance...
