Originally Posted by Ryan Caldwell
If you have the weight to play with, you may want to have your back wall be 60" tall to block all the low to the ground shooters.
While you are at it, make a 20" extension that swings up around a pivot right at the 59"-60" mark. That way you are even more of a nuisance to any shooter while nearby.
(artwork courtesy of yours truly
