Go to Post The amount of sense this rule makes is irrelevant. It is still the rule, and breaking this rule violates something that i'm sure all of you have heard of. Does gracious professionalism ring a bell? - Kate00 [more]
Unread 30-01-2014, 14:35
Kettering's Avatar
Kettering Kettering is offline
read. set. rebound rumble.
AKA: Steve Smitka
FRC #3098 (The Captains)
Kettering is just really niceKettering is just really niceKettering is just really niceKettering is just really niceKettering is just really nice
Re: pic: 3D printed 8-Slot cRio Digital Sidecar table
No, it only allows for two cards. We use the card guides inside to help secure the table in. You coudl probably move the legs in to allow for a 3rd card. We just posted the .step file so you can easily edit the table to use your own numbers.
Note: The holes are not perfect from table to digital sidecar, but this was done so that the leg would fit against the empty slots, making a tight fit. Use zip ties to connect the DS to table for best results.
Here's the link to .step and .stl files. http://www.thingiverse.com/thing:237694/
www.team3098.com
