Go to Post This isn't a golden ticket - it's a golden opportunity. It's up to you to earn it. - Jessica Boucher [more]
Unread 30-01-2014, 17:42
DampRobot's Avatar
Physics Major
AKA: Roger Romani
pic: VersaPlanetary Plate with Cams
Unread 30-01-2014, 17:46
Nuttyman54's Avatar
Mentor, Tactician
AKA: Evan "Numbers" Morrison
Re: pic: VersaPlanetary Plate with Cams
This is a pretty slick little setup. I'm curious as to why you need two cams though, shouldn't you only need one to react against the chain load?
If you just have two shown to demonstrate you can put them on either side, ignore my question.
Unread 30-01-2014, 18:13
I could be wrong, but wouldn't a tight bolted connection hold the gearbox in place just fine? Teams slot gearboxes all the time without needing cams to retain them. I could be missing something though.
Unread 30-01-2014, 18:22
R.C.'s Avatar
R.C. R.C. is offline
2017... Oooh Kill em, Swerve!
FRC #1323 (MadTown Robotics)
That would be dependent on load/setup, I've seen multiple setups work and multiple fail.
R.C.
MadTown Robotics Team 1323
Unread 30-01-2014, 21:49
DampRobot's Avatar
Physics Major
AKA: Roger Romani
Yeah, us too. A lot of stuff on FRC bots sees a ton of vibration, which tends to loosen screws. We've had some problems with the plates sliding in the past.
And, yeah, it's just to show that there are two places to put a cam.
-Plutarch
