Go to Post Perfection is less about effort or skill than it is about having a clear and limited goals. - SoftwareBug2.0 [more]
Unread 31-01-2014, 10:07
apalrd's Avatar
apalrd apalrd is offline
More Torque!
VRC #3333
Re: pic: 2637 Electronics Teaser
It looks very neat compared to most teams.
For the highest levels of neatness, here's a few tips:
-Run all wires in columns. So there would be column along the PD board, which makes a right turn to the plywood bridge, goes across, makes a right turn and then down the alley of talons. Face all of the talons with either power on the inside (so the center column in a 2x3 grid of talons has power in, and the outer columns have power out) or the same direction. Again, right turns around every corner, no cutting corners.
-Run PWMS first, under everything else. They are smaller and easier to manage.We usually run a column down the side of the DSC that goes to the talons or victors.
--Glue the PWM connections, we use silicone but I've heard hot glue works as well.
-Keep the main battery cable as short as possible. If the battery goes where the outline next to the main breaker is, then optimally the red wire between the battery connector and the main breaker is ~3in and the black is ~6in. The short red wire to the PD board is good.
-Strain relieve all wires to the board within a few inches of their device, usually using zip tie pads or holes through the material.
-Zip tie all wire bundles to either a zip tie pad or a hole in the material, every few inches (~6in).
-We have never used fans with our talons, and never had issues. Weight is weight.
-Don't wire over anything, always around.
Kettering Motorsports
