Go to Post When we design these systems ask " would I want my Mom (or daughter) standing next to this thing when it goes off? - Mike Betts [more]
  #31   Spotlight this post!
Unread 29-01-2014, 03:52
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
Re: pic: Battery connector.....
I'm just waiting for someone to show up with active cooling on their battery connector. (This isn't as ridiculous as it seems, if your intention is to follow the rules, and yet still extract maximum performance from your robot.)
I actually thought it was FIRST's intention to allow the SB120 (and other) connectors this year, when I noted on kickoff day that the rules referred to Anderson connectors without referencing the KOP checklist or the SB50 model. But it appears that in order to avoid undersized Anderson connectors being used, FIRST amended the rule to specify the SB50 only, rather than any SB-series connector rated by APP for at least 50 A. (Some teams were already using the SB120, which was at least plausibly legal in some years, but probably illegal in others.)
Originally Posted by Al Skierkiewicz View Post
Hold on so we get some real facts listed. The SB 50 was not introduced when we went to the IFI controllers. It became mandated much later. WildStang used a similar connector for many years prior to the start of the SB50.
I'm pretty sure the Anderson SB50 was included in the 2000 KOP when the first Stamp-based IFI controllers arrived. 188 certainly used them from 2000 to the present. In fact, I think it was provided in 1999 with the green batteries that were used prior to the grey Exides. (It's possible that one of the clones of the SB50, like the one produced by Tyco/TE Connectivity was supplied instead, but that should be immaterial in this context.) I'm not sure when the rules explicitly mandated an SB50 (either by lack of an alternative, or by name), but certainly the 2000s-era additional hardware list and Small Parts catalogue would have limited the legal alternatives.
  #32   Spotlight this post!
Unread 29-01-2014, 08:06
AKA: Big Al WFFA 2005
FRC #0111 (WildStang)
The SB50 was "recommended" in 2003 and 2004 but was not required until 2005 when the battery was no longer weighed with the robot. We used an Anderson 50 amp connector that Motorola used for attaching batteries to cell phone amps in the field. They use the same contacts in a different housing as I remember.
Al
WB9UVJ
www.wildstang.org
________________________
  #33   Spotlight this post!
Unread 29-01-2014, 08:30
Chadfrom308's Avatar
Chadfrom308 Chadfrom308 is offline
Slave to the bot
AKA: Chad Krause
FRC #0308 (The Monsters)
Chadfrom308 is a splendid one to beholdChadfrom308 is a splendid one to beholdChadfrom308 is a splendid one to beholdChadfrom308 is a splendid one to beholdChadfrom308 is a splendid one to beholdChadfrom308 is a splendid one to beholdChadfrom308 is a splendid one to behold
The monsters have never had this happend, but we did fry a couple of wires that were going to motors that got caught up and stalled.
Also, last year it probably didn't help that we had an OCCRA 80A breaker on our robot
Needless to say that is never going to happen again.
  #34   Spotlight this post!
Unread 29-01-2014, 10:39
Joe Ross Joe Ross is offline
FRC #0330 (Beachbots)
Rookie Year: 1997
It was required in 2004.
<R20> The 12v battery must be wired directly to a quick connect / disconnect connector (provided in the kit) that in turn feeds power to the Main Power Disconnect Switch and Circuit Breaker Assembly
  #35   Spotlight this post!
Unread 29-01-2014, 11:30
Yes,
But it is not identified as an SB50 nor is it shown on the electrical drawing. In the KOP it is not even listed as to manufacture.
Al
WB9UVJ
www.wildstang.org
  #36   Spotlight this post!
Unread 29-01-2014, 11:38
Rookie Year: 1997
Yes,
Q/A made it quite clear that only the SB50 was allowed that year, against Wildstang's objections in this thread: http://www.chiefdelphi.com/forums/sh...ad.php?t=24890
  #37   Spotlight this post!
Unread 29-01-2014, 12:42
OK, Joe, I knew this was a WildStang rule. It is all flooding back to me now. Thanks for finding the thread. As Aidan explained in that thread, Anderson was fully included in the testing at the time. We did some independent testing and thought our connectors were better but after further investigation at the time, we did adopt the SB50. We have now 10 years of use with our current style of battery and these connectors over thousands of matches. They seem to be doing very well. Even Raul eventually relented.
Al
WB9UVJ
www.wildstang.org
  #38   Spotlight this post!
Unread 30-01-2014, 10:03
Look what my students found last night while unpacking some stuff.
I will have to post the picture somewhere else, I can't post pics here.
Al
WB9UVJ
www.wildstang.org
  #39   Spotlight this post!
Unread 31-01-2014, 14:14
apalrd's Avatar
apalrd apalrd is offline
More Torque!
VRC #3333
Would it be possible for FIRST to allow both the SB-50 or SB-120? I can't imagine any issues (other than 'the rules don't allow it') to use the next size up connector.
Kettering Motorsports
  #40   Spotlight this post!
Unread 31-01-2014, 14:35
Rookie Year: 1997
I assume you've already seen Q81?
  #41   Spotlight this post!
Unread 31-01-2014, 14:44
apalrd's Avatar
More Torque!
VRC #3333
Yes. Very disappointing.
  #42   Spotlight this post!
Unread 31-01-2014, 14:47
Karthik Karthik is offline
VEX Robotics GDC Chairman
Karthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond repute
We specifically asked on the Q&A and were denied.
https://frc-qa.usfirst.org/Question/...ribution-board
:: Karthik Kanagasabapathy ::
"Enthusiasm is one of the most powerful engines of success. When you do a thing, do it with all your might. Put your whole soul into it. Stamp it with your own personality. Be active, be energetic, be enthusiastic and faithful and you will accomplish your object. Nothing great was ever achieved without enthusiasm" -- R.W. Emerson
My TEDx Talk - The Subtle Secrets of Success
Full disclosure: I work for IFI and VEX Robotics, and am the Chairman of the VEX Robotics and VEX IQ Game Design Committees
  #43   Spotlight this post!
Unread 31-01-2014, 15:41
I'd like to see a bigger connector, to allow for the use of 4ga wire without having to cut it down to fit in a 6ga terminal.
In 2003, we used some big single-pole Anderson connectors on our battery, and it was legal at that time. But, it was denied in later years.
  #44   Spotlight this post!
Unread 31-01-2014, 16:21
Bill_B Bill_B is offline
You cannot not make a difference
FRC #2170
Bill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond repute
Bigger connector is heavier, so to the extent that battery and attachment is excluded from the weight of the robot, a team using larger connectors can add more weight this way. Heavier wire and heavier connector = advantage? This is without current carrying advantage of some degree.
Nature's Fury FLL team 830 - F L eLements
FRC team 2170 - Titanium Tomahawks
  #45   Spotlight this post!
Unread 31-01-2014, 16:29
cgmv123's Avatar
cgmv123 cgmv123 is offline
FRC RI/FLL Field Manager
AKA: Max Vrany
FRC #1306 (BadgerBOTS)
cgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond repute
Negligible, in my opinion, especially compared to the weight of the battery. The current carrying advantage is the intent of a bigger connector.
BadgerBOTS Robotics|@team1306|Facebook: BadgerBOTS
2016 FIRST Championship Tesla Division | 2016 Wisconsin Regional Engineering Inspiration Award
2015 FIRST Championship Carson Division | 2015 Wisconsin Regional Chairman's Award
2013 FIRST Championship Curie Division | 2013 Wisconsin Regional Chairman's Award
2012 FIRST Championship Archimedes Division | 2012 Wisconsin Regional Engineering Inspiration Award, Woodie Flowers Finalist Award (Lead Mentor Ben Senson)
