Go to Post Did you know that if a G7, G27, G28, and G20 occur in that order at the same time, then the referee will appear to be doing the "YMCA"? :) - Jack Jones [more]
Unread 01-02-2014, 08:46
gpetilli gpetilli is offline
FRC #1559
gpetilli is a name known to allgpetilli is a name known to allgpetilli is a name known to allgpetilli is a name known to allgpetilli is a name known to allgpetilli is a name known to all
Re: pic: FRC488 - Octocanum Drive Rendering
Originally Posted by pwnageNick View Post
The 2.75" Double Roller Omni Wheels are also quite nice.
http://www.vexrobotics.com/276-1902.html
And if you don't like using the 1/8" square bore in them you can shove a 1/4" hex shaft through them. Some VEX teams have done it before with 1/4" hex standoffs (since that's a legal VRC part). You might be able to take it up to 3/8" hex if you machine it.
We are using the Vex dually as follower wheels. We even use the Vex encoders on the 1/8" shaft. We made 3d printed forks to hold it all together.
