Re: pic: Team 48 Something or Other
Looks suspiciously like a high goal blocker to me.
High goal blockers don't require 100:1 gearing.
Here's a random, shot in the dark guess. Does the pinion gear have some teeth missing, by design?
Based on the short size of your linear punch (that whole assembly is ~14 inches long, right?), I'm guessing you're doing some kind of arm / claw shooter. |
Magic 8 Ball says, "Outlook Good".
I'm quite excited to see this. We have a lot of similarities in our robot design. I only wish we had thought to use a clever mechanism like this instead of a winch and shifter. Did you find OTS rack gears that didn't weigh a ton or did you make your own?
Here is a test fire of the prototype at about 100 lbs. of tension. We are expecting to add some more tension for the final iteration: http://www.youtube.com/watch?v=5r2GO3_s-9s igus' Y.E.S. program (http://www.igus.com/wpck/4856) graciously supplied the 1" aluminum shaft we're using as the punch rod, as well as the open-top linear bearing pillow blocks (which conveniently let the 3/8" wide rack gear slide right through them, contributing to the compactness of the launcher design). One of the benefits of this linear punch design over others is that there is zero drag on the action from the unwinding of a winch spool. Last edited by Travis Hoffman : 03-02-2014 at 14:29. |
