Go to Post I guess true innovation is when you can actually harness physics to do what you want. Heck -- that sounds suspiciously like engineering. - JVN [more]
Unread 03-02-2014, 03:34
Bryce2471's Avatar
Alumnus
AKA: Bryce Croucher
FRC #2471 (Team Mean Machine)
pic: 2471's final winch assembly gear side
Unread 03-02-2014, 03:36
DampRobot's Avatar
Physics Major
AKA: Roger Romani
Re: pic: 2471's final winch assembly gear side
Color me impressed. That's a really neat little assembly.
Have you done any testing to see if you can get enough torque out of the PG-71 gearbox? In the past, we've had some problems with them failing at high torque loads.
Also, could you give us a bit more info on final ratio/load/travel/windup time/current for the system?
-Plutarch
Unread 03-02-2014, 09:18
MrBasse MrBasse is online now
FRC #3572 (Wavelength)
That looks nice, very well integrated components. I wouldn't worry too much about the PG71, we used two of them to lift our robot up the pyramid last year over 60 times with a 1.5" pulley. If two PG71's can dead lift 142 lbs over 450 feet in one season, I'm pretty confident that it can pull back your shooter. Then again, how much tension are you pulling back?
Andrew Basse
Unread 03-02-2014, 14:00
Bryce2471's Avatar
Alumnus
AKA: Bryce Croucher
Thanks. We haven't done any testing of the torque output yet. But the numbers say that it will be more than enough power.
The 18 volt 775 stalls at 166oz-in of torque or 10.3lb-in. After a 71:1 gear reduction that's 735lb-in. Our spool only has a 0.625" radius, so under perfect conditions it should stall producing 1180lbs of force. Multiply this by a rough torque efficiency of 0.75 and you get 880lbs.
Our shooter should take less than 200lbs to retract so the motor will be running in its happy place (about 10,000rpm) which should pull our cable at about 10in/sec. So it should get the job done in a little over 1 second. Of course it's all theoretical at this point.
FLL Team Future imagineers
FRC Team Mean Machine
Unread 03-02-2014, 16:51
amesmich's Avatar
amesmich amesmich is offline
FRC #4638 (Jagbots)
amesmich is an unknown quantity at this point
How is that ratchet released? is the tension taken off for the release?
Unread 03-02-2014, 16:53
amesmich's Avatar
FRC #4638 (Jagbots)
Disregard, I see in the other picture you used a cylinder to slide it.
Unread 03-02-2014, 17:11
Bryce2471's Avatar
Alumnus
AKA: Bryce Croucher
I think you've got the idea, except the cylinder does not directly slide the ratchet. The cylinder just disengages the spool from its shaft, so the ratchet is always engaged.
Unread 03-02-2014, 19:13
DampRobot's Avatar
Physics Major
AKA: Roger Romani
Interesting. Our 2 CIM worm gearbox with about an 80:1 final reduction with a 1" diameter pulley takes about 3 seconds to pull back our 130 lb shooter. I'd be interested in hearing your results when you test it on the robot.
-Plutarch
Unread 04-02-2014, 02:23
Bryce2471's Avatar
Alumnus
AKA: Bryce Croucher
We did our first tests of the system as whole today. I'd say it took about 2 seconds to retract our shooter. It measured at over 100lbs of force in its current configuration.
We did have an issue with triggering the shifter rod, but I expect that it will be fixed with some lubrication. Like one of our mentors always says "When in doubt, Lubricate!"
