Go to Post Any school official who isn't tickled pink by hundreds high school students, and teachers, and parents, and mentors spending their weekend celebrating STEM isn't a school official worth having. - Ian Curtis [more]
Unread 03-02-2014, 07:40
A_Reed's Avatar
A_Reed A_Reed is offline
Lead Design Mentor
AKA: Adam Reed
FRC #0048 (Delphi E.L.I.T.E)
A_Reed is a splendid one to beholdA_Reed is a splendid one to beholdA_Reed is a splendid one to beholdA_Reed is a splendid one to beholdA_Reed is a splendid one to beholdA_Reed is a splendid one to beholdA_Reed is a splendid one to behold
Re: pic: Team 48 Something or Other
Originally Posted by Whippet View Post
Looks suspiciously like a high goal blocker to me.
High goal blockers don't require 100:1 gearing.
Unread 03-02-2014, 10:01
Here's a random, shot in the dark guess. Does the pinion gear have some teeth missing, by design?
Based on the short size of your linear punch (that whole assembly is ~14 inches long, right?), I'm guessing you're doing some kind of arm / claw shooter.
Unread 03-02-2014, 10:32
O-H
FRC #0048 (Delphi E.L.I.T.E.)
Magic 8 Ball says, "Outlook Good".
Unread 03-02-2014, 11:29
I'm quite excited to see this. We have a lot of similarities in our robot design. I only wish we had thought to use a clever mechanism like this instead of a winch and shifter. Did you find OTS rack gears that didn't weigh a ton or did you make your own?
Unread 03-02-2014, 14:25
O-H
All gears are steel and were purchased from AndyMark, including the 56-T pinion. We bought the 20 DP, 14.5* PA rack gear from McMaster (http://www.mcmaster.com/#6295K113). The total stroke of the unit is 6" (incl. 4" of ball contact), so the rack isn't that heavy.
Here is a test fire of the prototype at about 100 lbs. of tension. We are expecting to add some more tension for the final iteration:
http://www.youtube.com/watch?v=5r2GO3_s-9s
igus' Y.E.S. program (http://www.igus.com/wpck/4856) graciously supplied the 1" aluminum shaft we're using as the punch rod, as well as the open-top linear bearing pillow blocks (which conveniently let the 3/8" wide rack gear slide right through them, contributing to the compactness of the launcher design).
One of the benefits of this linear punch design over others is that there is zero drag on the action from the unwinding of a winch spool.
Unread 03-02-2014, 14:37
eddie12390's Avatar
eddie12390 eddie12390 is offline
AKA: Eddie
FRC #3260 (SHARP)
eddie12390 is a glorious beacon of lighteddie12390 is a glorious beacon of lighteddie12390 is a glorious beacon of lighteddie12390 is a glorious beacon of lighteddie12390 is a glorious beacon of light
I can't wait to see this in person at the Greater Pittsburgh Regional. I can still remember your bot from 2012.
