Go to Post Also, the judges don't give out awards for money. They give out awards for hard work and effort. - BigJ [more]
Unread 05-02-2014, 10:55
theawesome1730's Avatar
theawesome1730 theawesome1730 is offline
FRC #1730 (Team Driven)
theawesome1730 will become famous soon enough
Re: pic: coupling for dual cylinder ballshifter
We can shoot ours by hand after we added a lever arm to a custom dog gear. Your design looks so refined and professional. If I didn't know better I'd have said it came from vex
2015 GKC Engineering Inspiration
2015 Colorado Winners
Unread 05-02-2014, 12:28
tag_groff's Avatar
tag_groff tag_groff is offline
FRC #4265
tag_groff is an unknown quantity at this point
Thank you so much. This is one of my favorite mods that we have ever done to a ball shifter
Unread 05-02-2014, 12:39
Since we can't 3D print, we ended up doing something a bit weirder / more foolish for our solution. We made a custom coupler that mimics the interface of the 10-32 rod and nut. Attached to the other end of this coupler is a female tapped hole for a 1.5" bore piston. That way we could use the off-the-shelf coupler but still throw more power into a system that probably needs it.
Unread 05-02-2014, 22:14
IceStorm IceStorm is offline
Mentor FRC 5046, FTC 8688
AKA: Chad
FRC #5046 (Jacked Up Jackets)
IceStorm is a glorious beacon of lightIceStorm is a glorious beacon of lightIceStorm is a glorious beacon of lightIceStorm is a glorious beacon of lightIceStorm is a glorious beacon of light
Send a message via AIM to IceStorm Send a message via Yahoo to IceStorm
Originally Posted by Jon Stratis View Post
How much force are you putting on this? Our winch uses a 2-CIM Ball shifter as well, and we were able to shift it under competition-load from our catapult (we haven't fine tuned it yet, but it's close to where it'll be) using only 20 PSI!
Were using quite a bit of force on ours. We had it working when using the high gear where it had to push the cylinder out of place but when we switched to using the low gear it didnt have the force to pull it free. our goal was to be able to pull it back enough to shoot from about 18 ft or so.
thank you for sharing the file. trying to find a way to get it printed out now is the next big challenge.
