Go to Post We've done all the speculation we can do (some of us with less knowledge than others); let's rest our minds and keyboards and wait. - Astrokid248 [more]
Unread 15-02-2003, 18:52
CD47-Bot CD47-Bot is offline
FRC #0047 (Chief Delphi)
Image Discuss: Team 773 Stacking
Unread 15-02-2003, 18:53
Mullen's Avatar
Mullen Mullen is offline
FRC #0573 (Mech Warriors)
Mullen is a glorious beacon of lightMullen is a glorious beacon of lightMullen is a glorious beacon of lightMullen is a glorious beacon of lightMullen is a glorious beacon of lightMullen is a glorious beacon of light
hmm, looks to me that the light would be deamed illegal unless it pivots with servo or sumtin else, might wanna change that around
2002-2003 : 573 Mech Warriors: Student
2005-2007 : 1504 Desperate Penguins: Mentor
2012 - ? : 573 Mech Warriors: Mentor
Try as I may, I can't stay away.
Unread 15-02-2003, 18:59
Fridge Fridge is offline
AKA: Cole Stewart
#0773 (The Kingsville Kukes)
Fridge is on a distinguished road
Send a message via ICQ to Fridge
Why?
Why would you say that the light would be illegal? Is it the horizontal rule, or are you worried about how well it's protected? Whe whole arm pivots and is horizontal most of the time, and it doesn't come in contact with much. Oh well, thanks for the help in advance.
Cole Stewart
cstew@cogeco.ca
http://www.kingsville1st.com
5th Seed @ CR
http://fridge.freeshell.org
ICQ: 16210050
Unread 15-02-2003, 19:01
Gadget470's Avatar
Gadget470 Gadget470 is offline
A Fire Outside
AKA: Brandon Joerges
no team (Alpha Omega)
Gadget470 is a jewel in the roughGadget470 is a jewel in the roughGadget470 is a jewel in the roughGadget470 is a jewel in the rough
Send a message via ICQ to Gadget470 Send a message via AIM to Gadget470
Who knows what illegal for the light anymore..
That doesn't look to well protected from impact though.
Unread 15-02-2003, 19:06
Mullen's Avatar
from what i understand the light has to be vertical for "99%" of the time, it may be protected but they might not like the horizontal aspect
Unread 15-02-2003, 19:16
AKA: Cole Stewart
whoops
I should have chosen my words more carefully, when I said horizontal, I meant that the surface that it is mounted to will be horizontal much of the time, not 99% but a lot. Because the light is perpendicular to the surface, it will be veritcal. When the arm is raised the light is also be well protected. And like Gadget said, Who knows what's legal or illegal with the light anymore? Who knows, maybe the mystical Team Update #15 will have the answers.
Cole Stewart
cstew@cogeco.ca
5th Seed @ CR
ICQ: 16210050
Unread 15-02-2003, 19:23
Mullen's Avatar
i also should have chosen my words better, the light has to be upright, so if the arm its on is down most of the time, it looks like the light might be upside down, thus being illegal, and if the arm is up for more than say 4 seconds at a time and causing the light to be horizontal during that time then that would also be illegal...they say that for low bots who travel under the bar if the light sticks up it can swirve upside down for the time it takes to go under the bar, but then it must return to the vertical position as soon as possible, they figure 3-4 seconds would be the average allowable time
Unread 15-02-2003, 19:35
Todd Derbyshire's Avatar
Todd Derbyshire Todd Derbyshire is offline
Alumni
Todd Derbyshire will become famous soon enoughTodd Derbyshire will become famous soon enough
The light rule I think is ridiculous. As long as you got a light on your bot and it works for the first second of the match its good. It serves the purpose of a light. If it breaks then guess what its not your fault and I think many people shouldn't be sticklers on where and how they put a light on their bot. Seriously if the light emits a color and spins it works end of story. I find it ridiculous that the first reply to this thread and many others not just this one is your light is illegal. Let's not disect mute points such as this and instead just congratulate them for what appears to be a very solid robot. Good job guys! Ok I'm done ranting now but that has been irking for a long time
119=190 right?????
Unread 15-02-2003, 19:40
Mullen's Avatar
ok, im not trying to down their robot,it looks solid, and im not a person whos really happy about the light ruling either, but FIRST probobly will be quite tough on the light, like they said they would be. i just dont want them to show up at the competition and have to redesign a mount for their light because the inspectors say its illegal
Unread 16-02-2003, 01:09
sevisehda's Avatar
sevisehda sevisehda is offline
sevisehda is an unknown quantity at this point
Send a message via AIM to sevisehda
I doubt placing it upside down would matter but when the arm is up it looks like the arm would block the light from the rear.
The light is supposed to identify the bot for the fans, true it gets in the way but its the easiest solution. At least its better than those colored apron things they made us wear in gym in elementary school. So if you have a better solution submit it for Y2K4.
Unread 16-02-2003, 01:29
AKA: Cole Stewart
Visibility
On the other side of the light on the arm is a sheet of clear lexan with some stickers on it. I don't think that visibility would be a big issue although I guess light can't come out of the black plastic bottom of the light. However, the arm does not do much to reduce the lights visibility.
Cole Stewart
cstew@cogeco.ca
5th Seed @ CR
ICQ: 16210050
Unread 16-02-2003, 02:18
Clanat Clanat is offline
Custom Title
#0753 (High Desert Droids)
Clanat has a little shameless behaviour in the past
Can it flip boxes into the correct position to lift them?
Former Co-Captain
Winner NW Regional 2002 and 2003
Unread 16-02-2003, 21:50
AKA: Cole Stewart
boxes
We can pick up boxes that are on their side or that are upright. The only ones we have some trouble with are ones that are upside down, but were finding ways of pursuading them into the proper orientation .
Cole Stewart
cstew@cogeco.ca
5th Seed @ CR
ICQ: 16210050
Unread 05-04-2003, 22:59
AKA: Cole Stewart
For the record...
For the record, no one saw the light as a problem in competition and it was never really a problem. BTW, thanks to our alliance partners @ the Canadian Regional, BlueLightning 578 and 1036 blues. We did alright, both QF matches were close, closer than the scores show.
Cole Stewart
cstew@cogeco.ca
5th Seed @ CR
ICQ: 16210050
Disqualifications archiver 1999 13 23-06-2002 21:53
