Go to Post Teamwork gracious professionalism robots = FIRST Robotics - Bcahn836 [more]
Unread 09-02-2014, 20:41
nathannfm's Avatar
AKA: Nathan
FRC #3940
pic: Warning about Loctite touching ABS or Polycarbonate
Unread 09-02-2014, 20:44
cbale2000's Avatar
cbale2000 cbale2000 is online now
AKA: Chris Bale
FRC #0703 (Phoenix)
Re: pic: Warning about Loctite touching ABS or Polycarbonate
I can't speak to ABS, but we've used Loctite dozens of times with screws in tapped polycarbonate without any issues. Perhaps the specific kind of Loctite or polycarbonate you're using is more susceptible to problems?
Unread 09-02-2014, 20:50
Steven Donow Steven Donow is offline
AKA: Scooby
Steven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond repute
Here's the previous post Nathan was talking about, I believe. I assume it's the specific type of plastic AndyMark uses with that certain type of Loctite.
http://www.chiefdelphi.com/media/photos/37661
eddie12390's Avatar
eddie12390 eddie12390 is offline
AKA: Eddie
FRC #3260 (SHARP)
eddie12390 is a glorious beacon of lighteddie12390 is a glorious beacon of lighteddie12390 is a glorious beacon of lighteddie12390 is a glorious beacon of lighteddie12390 is a glorious beacon of light
Acetone (the solvent used in a lot of thread locking compounds) dissolves ABS plastic. A lot of 3D model makers will use it to smooth out their creations as it can eat the plastic.
Unread 09-02-2014, 20:59
nathannfm's Avatar
AKA: Nathan
FRC #3940
If it helps "Loctite 222MS" was what caused what is pictured, that has since run out and we switched to Loctite 242, I can test some of that on the broken part and see if it reacts differently.
Unread 09-02-2014, 21:05
eddie12390's Avatar
AKA: Eddie
FRC #3260 (SHARP)
I wouldn't recommend it, the following is taken from http://www.loctiteproducts.com/p/t_l...r-Blue-242.htm
Code:
Not Recommended For
    Use in pure oxygen and/or oxygen rich systems and should not be selected as a sealant for chlorine or other strong oxidizing materials
    Use on plastic parts, particularly thermoplastic materials where stress cracking of the plastic could result
Unread 09-02-2014, 21:10
nathannfm's Avatar
AKA: Nathan
FRC #3940
Code:
Not Recommended For
We found a way to apply it so it won't touch the plastic which only has clearance holes. (we assumed they were both bad for plastic)
Unread 10-02-2014, 09:36
artdutra04's Avatar
VEX Robotics Engineer
If you need to use thread-locker on plastic parts such as PC or ABS, it's better to buy screws that have a nylon lock patch already installed, as this will not dissolve the plastic.
http://www.mcmaster.com/#thread-locking-screws/
Art Dutra IV
世上无难事,只怕有心人.
Unread 10-02-2014, 10:24
itsjustmrb itsjustmrb is offline
FRC #4063 (TRikzR4kiDz)
itsjustmrb is a splendid one to beholditsjustmrb is a splendid one to beholditsjustmrb is a splendid one to beholditsjustmrb is a splendid one to beholditsjustmrb is a splendid one to beholditsjustmrb is a splendid one to beholditsjustmrb is a splendid one to behold
You might want to try Loctite 425 Assure Plastic Fastener Blue Threadlocker or Permatex 19920 Plastic Threadlocker. I have not personally tried these, but they are made for plastic.
Mr. B
2016 Hub City Regional Winner #3 Seed (3310 & 4301)
2016 Bayou Regional Winner #1 Seed (233 & 4087)
2015 Dallas & Alamo Creativity Award
2015-2016 Hub City Regional Gracious Professionalism
2014 Hub City Regional Engineering Inspiration
2012-2016 Alamo Regional Gracious Professionalism
2016 Bayou Regional Gracious Professionalism
2014 Dallas Regional Gracious Professionalism
2013 Alamo Regional Winners (2468 & 2789)
Unread 10-02-2014, 10:27
ToddF's Avatar
ToddF ToddF is offline
mechanical engineer
AKA: Todd Ferrante
FRC #2363 (Triple Helix)
From the loctite website:
Threadlockers are a single component anaerobic adhesive comprised of unique liquid resins that harden (or cure) to a durable solid when exposed to metal ions in the absence of air. The anaerobic cure mechanism allows the adhesive to flow and evenly settle to lock and seal threaded fasteners without curing permanently. Any excess threadlocker will remain liquid, and is easily wiped away from the assembly.
I took a workshop on loctite adhesives once. Note that Loctite makes many types of adhesives, not just the threadlockers we normally identify them with. One thing they emphasized in the training is that anaerobic adhesives are not compatible with most plastics, and polycarbonate is especially vulnerable. An interesting fact is that the red plastic bottles they use for most of their threadlockers is microscopically vapor porous, like an eggshell or goretex. This prevents the threadlocker from curing in the bottle.
Loctite does make a threadlocker specifically for plastic parts and plastic fasteners. It's Loctite 425. This is cyanoacrylate (superglue) based, rather than anaerobic. Cyanoacrylates cure in the presence of water vapor. So this stuff comes in a bottle designed to keep air out, rather than allowing it in.
The workshop was really cool. They had all sorts of fun little demos that showed how the various products worked. One of these was a demo of the green product used to lock slip fit cylindrical parts. They gave us a collar and a piece of shaft. You put a drop of the adhesive on the joint and immediately started moving it back and forth, preventing the polymeric bonds from forming. As long as you kept moving the joint, it stayed liquid. If you stopped for a second, the adhesive would harden instantly.
Todd F.
Photo gallery
video channel
Triple Helix mobile
