Go to Post A problematic dynamic and culture becomes apparent when failure persists for such a duration and reoccurs so frequently that students begin to accept it as the norm, and never learn the proper way to do things. - sanddrag [more]
Unread 09-02-2014, 22:46
Canon reeves Canon reeves is offline
FRC #4490
Canon reeves has much to be proud ofCanon reeves has much to be proud ofCanon reeves has much to be proud ofCanon reeves has much to be proud ofCanon reeves has much to be proud ofCanon reeves has much to be proud ofCanon reeves has much to be proud ofCanon reeves has much to be proud ofCanon reeves has much to be proud of
pic: Here is the Before picture, Stay Patient for the After!
Unread 09-02-2014, 22:48
Dkt01's Avatar
Dkt01 Dkt01 is offline
Programming Mentor
AKA: David
FRC #1756 (Argos)
Dkt01 will become famous soon enough
Re: pic: Here is the Before picture, Stay Patient for the After!
It looks like you may have exposed lugs on the battery and the circuit breaker, which could enable accidents. Try covering exposed metal with heat shrink tubing or electrical tape to make everything safer.
Unread 10-02-2014, 09:53
FRC #4490
Ok, we will get after that this afternoon, thank you for the advice!
Unread 10-02-2014, 10:50
FRC #4490
Do yall think we should cover the main breaker's off switch?
Unread 10-02-2014, 10:52
JohnSchneider's Avatar
JohnSchneider JohnSchneider is offline
JohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond repute
You won't pass inspection. The main breaker has to be easily accessible and marked in case of emergency.
Unread 10-02-2014, 11:26
FRC #4490
Ok, that is why we put it up there, we were just kind of afraid of it getting hit and turned off but it can't be by the ball.
Unread 10-02-2014, 12:50
Whippet's Avatar
Whippet Whippet is offline
MIT Class of 2020
AKA: Luis Trueba
FRC #4301 (New Tech Narcissists)
Whippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond repute
Send a message via Yahoo to Whippet
If that is the case, you can probably put an open-ended box around it, so that the ball can't get in, but peoples' hands can. Just make sure that the opening in said box is fairly large.
2010: FRC 3043, Build Assistant
2011: FRC 3043, Head of Minibot subteam; FLL 12762, Team Captain
2012: FRC 3043, Electrical; FLL 12762, Team Captain; FTC 5670, Team Captain
2013: FRC 4301, Electrical, Team Co-Captain
2014: FRC 4301, Electrical/Programming, Team Co-Captain
2015: FRC 4301, Electrical/Programming, Team Captain
2016: FRC 4301, Chief Technical Officer; FTC 10860, 10861, and 11004: Mentor. Winner, Hub City Regional (3310 & 4063)
