Re: pic: Team 48 - Lock n' Load
The high power shot is selected by extending the 2 3" stroke cylinders, which adds 3" of pre-load onto the springs. The motor/gearbox pulls the springs back to firing position (roughly 6" of pullback). When the launcher fires, the majority of the stroke takes place with the ball in contact with the ram. The ram is 1" round igus aluminum rod with a McMaster 3/8" wide, 20 DP, 14.5 PA rack gear affixed. The rod slides through two open-top igus linear bearing pillow blocks. I actually don't know how much the ram weighs. The overall claw/launcher combo projects to weigh around 35 lbs. I was kinda thinking a .30 or .50 cal machine gun, but I think I like yours better. :-) Last edited by Travis Hoffman : 10-02-2014 at 23:39. |
Holy Perspective! It looks like its 4 feet tall
The main structural element is 4" x 4" x 1/8" wall aluminum, if that helps.
Fixed
Our linear launcher (not actually a puncher, but similar) uses aluminum extrusion with those same dimensions as its main structure, and our winch gear system is integrated, so our aluminum box structure serves both as a gearbox and launcher track all in one piece. Since our launcher stores a ridiculous amount of energy, we now understand that these types of ball shooting mechanisms may just need that much structure!
That is terrifyingly awesome. Great job as always!
Any reason for the tiny little pusher plate? Or are you going to replace this with something else? |
The igus linear bearings and aluminum shaft are also (literally) quite slick. Quote:
Hi Travis
How far are you hitting the ball? |
#10
This looks like a really long shot but I'm assuming that the camera perspective affects it a bit. What is the maximum effective range of this launcher?
#11
Our low power shot was hitting from about 16' tonight.
#12
Is that shots from 16' into the goal, 16' to hit the ground, or something else?
#13
I know nothing is going to happen but i sure would like to see a steel cable thru the center of that spring. I just don't see a way to hook one up in this picture. Maybe once it is mounted. I worked on garage doors for 30 years. Please be careful.
#14
I can almost wrap my head around how it works, but not quite.... How are you selecting the high or low shots? I think I understand, but am not positive...
I can't believe how compact it is. I thought it was huge until I recognized that it was in a vice, and then everything else started coming into perspective. It's definitely one of the coolest things I've seen so far :) |
#15
I hope the catapult folks (and safety inspectors) are equally as concerned with the high velocity tips of catapult arms weakening, breaking, and launching into space at some point. ;-) Quote:
The cylinders only affect the setting for the shot power. They are fully independent from the motor/gearbox-driven rack/pinion mechanism that cocks and fires the ram. There are two shot power settings: Low power setting - cylinders are retracted. Motorized rack and pinion stretches the springs about 6" total from a barely-stretched starting point. Higher power setting - cylinders are extended to 3" stroke, Pre-stretching the springs 3". Motorized rack and pinion stretches the springs 6 additional inches for a total deflection of 9". A carriage rides on round bearings inside the 4" x 4" shell. This carriage is driven by the two shot power cylinders - it moves the steel shoulder bolts to which the front spring loops are attached - these shoulder bolts travel inside slots milled into the sides of the 4" x 4" (this is the part that looks like a cocking lever on a machine gun). The rear spring loops are attached to a steel crossbar running through the back of the 1" aluminum ram. The shot select system can be actuated independently from the motor/gearbox cocking mechanism. I will try to get closeup video of this actuation tomorrow. The motor/gearbox drives a 20 DP 56T steel pinion gear with about 6 linear inches of teeth on it - the rest of the teeth are cut off, creating a "flat" on the gear. The pinion teeth engage with the steel rack gear attached to the 1" aluminum ram, stretching the springs and cocking the launcher back. To fire, we simply run the pinion into the "flat" zone, permitting the springs to release their energy and the ram to fire forward. We run the pinion from the flat zone to the mesh zone to re-$@#$@#$@#$@# [<-- HAHAHAHA re-"male chicken"] the launcher and repeat the process. We only run the motor/gearbox in one direction - there is a ratchet integrated into the gearbox for anti backdrive. Last edited by Travis Hoffman : 12-02-2014 at 03:15. |
