Go to Post And who knows, maybe one day you'll prove the impossible possible! - MissInformation [more]
Unread 12-02-2014, 22:10
Rauhul Varma Rauhul Varma is offline
Drivetrain and Design Lead
FRC #0192 (GRT)
Rauhul Varma has much to be proud ofRauhul Varma has much to be proud ofRauhul Varma has much to be proud ofRauhul Varma has much to be proud ofRauhul Varma has much to be proud ofRauhul Varma has much to be proud ofRauhul Varma has much to be proud ofRauhul Varma has much to be proud ofRauhul Varma has much to be proud of
pic: Team 192's 2014 Gearbox
Unread 12-02-2014, 22:14
s_forbes's Avatar
s_forbes s_forbes is offline
anonymous internet person
FRC #0842 (Falcon Robotics)
Re: pic: Team 192's 2014 Gearbox
Beautiful. I suspect that the multiple mounting points for each CIM are to vary the belt tension? Also curious on what you did to manufacture the plate with a gradual and accurate bend. The details on this gearbox are amazing!
Unread 12-02-2014, 22:17
MetalJacket's Avatar
MetalJacket MetalJacket is offline
Has read the 2014 manual
AKA: Jesse Gibson
FRC #2068 (The Metal Jackets)
MetalJacket has a spectacular aura aboutMetalJacket has a spectacular aura aboutMetalJacket has a spectacular aura about
Wow, almost thought that was a render at first. Neat idea using pulleys for your first stage of reduction - I'm guessing that was to allow you to locate your output shaft off to the side like it is (motors over the wheel well?).
Team Role = !artTeam
2011 - Logomotion
- Virginia Regional : Tournament Semi-Finalist, Gracious Professionalism Award
2012 - Rebound Rumble
- Chesapeake Regional : Tournament Finalist, Gracious Professionalism Award
2013 - Ultimate Ascent
- Virginia Regional : Gracious Professionalism Award
Botwoon's Avatar
Botwoon Botwoon is offline
A.K.A. Matthew Ruane
FRC #0207 (Metalcrafters)
Botwoon will become famous soon enough
Beautiful gearbox, as usual.
Unread 12-02-2014, 22:23
FRC #0192 (GRT)
Firstly, thank you! Your guess is exactly what they are, they adjust the CIM's C-C Distance from +0 thou to +50 to account for manufacturing tolerances. As for the shield, the one pictured was actually manufactured by one of our sponsors but we are in the process of making a rig to bend the plates. Once they are completed/anodized we will be replacing them with ours. (We are testing different curves for bending so that once the plate springs back from the bend it will be in the correct shape)
Unread 12-02-2014, 22:26
FRC #0192 (GRT)
I did use belts on the initial reduction so I could put the motors wherever I wanted and the motors do hang over the center wheel.
Unread 12-02-2014, 22:46
Steven Donow Steven Donow is offline
AKA: Scooby
Steven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond repute
I've yet to see a gearbox from you guys that isn't a work of art. Such s nice gearbox
Unread 12-02-2014, 22:51
Jno
FRC #0610 (Crescent Robotics)
Just incredible, so compact and light. Never thought of using belts on the motors, the weight savings must be huge.
Co-Founder of Taplytics.com
Unread 12-02-2014, 22:56
Joey Milia's Avatar
FRC #0192 (GRT)
That has just been the past few years. Glad to see a tradition getting started though!
Unread 12-02-2014, 23:00
roystur44's Avatar
Mentor/Sponsor
AKA: Roy Dumlao
FRC #4543 (Apollo Robotics)
Great job,
Would love to see the other side with the gear shifting layout. Is there a encoder on the transmission? Neutral?
Roy Dumlao
Mentor/Sponsor
2006-2012 971
2013-2017 4543
Unread 12-02-2014, 23:15
FRC #0192 (GRT)
Originally Posted by roystur44 View Post
Great job,
Unfortunately I'm not sure when I will be able to post a side view as, but I can give you a some details and will post a picture once the others are assembled.
The gearbox features a custom ball shifting mechanism running at 19.5 ft/s and 8.5 ft/s with VexPro (originally 1/2" Hex) Gears on R10 Open bearings from USA Bearings and Belts (unlike the bushing in the VexPro gearbox). There is an encoder from US Digital encoder (S4-120-250-N-S-B) on a 3D printed mount connected to the shaft with the two black plastic pulleys via a section of 1/4" ID surgical tubing.
Unread 12-02-2014, 23:29
BBray_T1296's Avatar
I am Dave! Yognaut
AKA: Brian Bray
I am surprised you opted to have the 2 CIMs with the pulleys at the shaft tips and the one with the pulley at the bushing.
Is there any specific reason for this? I would have thought the other way around would be better.
Unread 12-02-2014, 23:35
FRC #0192 (GRT)
The main reason reason was so that the various mounting holes for the motors were not covered up by a belt, also I prefer having the longer lengths of belts closer into the plate.
Another thing I forgot to mention, the gearbox actually is 2 CIMs and 1 MiniCIM, with a CIM and MiniCIM sharing a belt.
Unread 13-02-2014, 05:30
Answer42's Avatar
Answer42 Answer42 is offline
Answer42 has much to be proud ofAnswer42 has much to be proud ofAnswer42 has much to be proud ofAnswer42 has much to be proud ofAnswer42 has much to be proud ofAnswer42 has much to be proud ofAnswer42 has much to be proud ofAnswer42 has much to be proud ofAnswer42 has much to be proud ofAnswer42 has much to be proud of
You guys have certainly elevated drive train gearboxes to an art form. I think the thing that strikes me about them is the level of detail and thought put into them is not often seen in a six week design window, even from the great teams. Good luck this season
My comments do not reflect the views of associated teams.
Unread 13-02-2014, 10:06
DampRobot's Avatar
Physics Major
AKA: Roger Romani
Originally Posted by Answer42 View Post
... not often seen in a six week design window...
I believe they at least partially develop thse gearboxes in the fall.
-Plutarch
