Go to Post I dont compete to win prizes, I compete to win Pride. - CircularLogic [more]
Unread 16-02-2014, 19:37
Peyton Yeung's Avatar
Peyton Yeung Peyton Yeung is offline
45 Alumni
AKA: Peyton Yeung
Peyton Yeung has a reputation beyond reputePeyton Yeung has a reputation beyond reputePeyton Yeung has a reputation beyond reputePeyton Yeung has a reputation beyond reputePeyton Yeung has a reputation beyond reputePeyton Yeung has a reputation beyond reputePeyton Yeung has a reputation beyond reputePeyton Yeung has a reputation beyond reputePeyton Yeung has a reputation beyond reputePeyton Yeung has a reputation beyond reputePeyton Yeung has a reputation beyond repute
Re: pic: FRC525 2014 Robot Render
Originally Posted by Tom Ore View Post
Here is a link to the file:
https://dl.dropboxusercontent.com/u/...lAssistSim.zip
From the students:
A simulation of this year's game with our robot, created in Unity3d. The menu has 4 buttons. Practice modes are not timed and can be exited from the pause menu (Esc). Double screen requires 2 monitors with the same resolution to be setup in extend mode (extend mode is when the desktop only shows up on 1 screen). Single screen is an overhead view, and double will put the 2 views in both teams' driver stations. Joysticks will be assigned based on the order they are plugged in. It will fill blue's team first, then red's. Controls are set up to use the 3rd axis (twist) on the joystick. These controls will not work with a 2 axis joystick or most controllers, so if you have any of those you can press the button the menu to toggle using the 2nd axis (side to side) instead of the third. Shoot on joysticks is the trigger, and the side button will pass. If you don't have those buttons, or are on a controller, they should be button 1 and 2 respectively (xbox controller uses A and B). To pick up the ball, back into it and the pickup will deploy automatically. If you don't have a enough joysticks you can use this handy chart for keyboard controls: http://www.imgur.com/wr8NwGR
Thanks a lot. very nice job.
461 Westside Boiler Invasion
2016 Tippy Quarter finalist, Warren Finalist, IN State Semi Finalist,B^3 Double Finalist
2015 Indy Semi finalist, Purdue Quarter Finalist, IN State Quarter Finalist, CORI QF, R2OC Finalist, RAGE Winner
2014 Boilermaker Semi finalist, Crossroads Quarter Finalist, & CAGE Quarter Finalist
45 Technokats
2013 Boilermaker Quarter finalist
2012 CAGE Semi finalist & Queen City Champion
2011 CAGE Quarter finalist & Midwest Semi finalist
2010 CAGE Quarter finalist, Boilermaker Champion, & Washington DC Quarter Finalist
Unread 02-03-2014, 11:04
Tom Ore Tom Ore is offline
FRC #0525 (Swartdogs)
We had a couple of questions at CIR about the render - it was done in Creo.
The robot ran well for most of the event and our drive team was outstanding.
We had one issue late in the eliminations rounds. One of our pots came loose and we lost the preset positions for our main ball pickup. This interfered with some auto and teleop shots. By the time we figured out what was wrong it was too late to fix it. We ran the last finals matches with out shooting at all -1986 picked up the shooting roll and were awesome!
I'm not sure if the pot was never tightened properly or if the heavy defense helped work it loose - we'll consider adding threadlocker to the pots for Queen City.
Unread 02-03-2014, 11:20
Michael Hill's Avatar
We were curious why you guys weren't shooting in auto in elims. That explains it
Unread 02-03-2014, 11:25
I was up in the stands at the time and feared the worst - I'm glad it wasn't some sort of catastrophic failure.
Unread 02-03-2014, 12:21
Bruce Newendorp Bruce Newendorp is offline
Engineer
Bruce Newendorp is a splendid one to beholdBruce Newendorp is a splendid one to beholdBruce Newendorp is a splendid one to beholdBruce Newendorp is a splendid one to beholdBruce Newendorp is a splendid one to beholdBruce Newendorp is a splendid one to beholdBruce Newendorp is a splendid one to behold
About halfway through the timeout between F2 and F3 we discovered the pot body had rotated slightly causing the pickup arm to be out of position. The few minutes remaining were not enough to tighten it and reset the zero point.
At Queen City we will hot glue the body to the gear box and use threadlock.
We also had a battery retaining bracket break during F2 and we spent most of the timeout zip tying the battery in place.
Overall it appears we survived the finals carnage without significant damage.
