Go to Post "You fogot the gears!!!!" - The_Gman [more]
Unread 19-02-2014, 14:24
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
Re: pic: Another Teleop while loop
If "stop" isn't true, then putting that while loop in Teleop will keep the rest of the robot program from running. I would expect to see communication issues indicated on the Driver Station.
Since you don't have any sort of delay in the loop, it will also use up all of the CPU time setting the motor output as fast as it can.
