Re: pic: 4918 Ready to Rock
Capabilities as of 2/18/14 include:
Simple High Goal Autonomous Short range High Goal shots Low Goal shots from the white line Low Goal shots from the front of the low goal White line to white line Truss shots Short pass capabilities both front and back Drive base: 6WD AM14U Kit Chassis, long configuration with drop center wheel 6x VexPro 4.0" Versawheels (Yes, we have spares) VexPro 2 CIM Ball shifters geared at 6.60:1 and 15.00:1 (2.27x spread) Catapult: 2x 1.125 Bore 10.0 Stroke cylinders (gravity return instead of air return for higher exhaust flow). VexPro Versaframe construction (Good grief, that 1x1 tubing is LIGHT) reinforced with strategic gusseting Multiple shot modes using solenoid pulsing Catapult weight ~10 lbs with upper frame assembly Ball loader (Nicknamed "The Hyneman", see http://www.youtube.com/watch?v=AjQhLI5mT_o): PVC construction for easy replacement at competitions Surprisingly resilient despite best efforts of the drive team in practice Easily clears bumpers Loads on the run at multiple speeds Entire assembly can be replaced in 5 minutes or less Extension length <20" When fully retracted, compresses ball onto the robot for snug fit Loader weight ~1.9 lbs Final Robot Weight: ~75 lbs. SPECIAL THANK YOU TO TEAMS 360 AND 3826!! |
