Go to Post According to that logic, Engineers would say there will be twice as many spectators as needed, and we all know that's not the case! - Taylor [more]
Unread 19-02-2014, 15:28
Racer26 Racer26 is offline
Re: pic: 4918 Ready to Rock
I hope I'm wrong, but it looks too wide, for a long configuration bot.
Does it fit inside the 112" perimeter?
To do an AM14U in long configuration you needed to cut the churro tubes and the endplates down by ~4" IIRC.
Originally Posted by AustinH View Post
Capabilities as of 2/18/14 include:
Simple High Goal Autonomous
Short range High Goal shots
Low Goal shots from the white line
Low Goal shots from the front of the low goal
White line to white line Truss shots
Short pass capabilities both front and back
Drive base:
6WD AM14U Kit Chassis, long configuration with drop center wheel
6x VexPro 4.0" Versawheels (Yes, we have spares)
VexPro 2 CIM Ball shifters geared at 6.60:1 and 15.00:1 (2.27x spread)
Catapult:
2x 1.125 Bore 10.0 Stroke cylinders (gravity return instead of air return for higher exhaust flow).
VexPro Versaframe construction (Good grief, that 1x1 tubing is LIGHT) reinforced with strategic gusseting
Multiple shot modes using solenoid pulsing
Catapult weight ~10 lbs with upper frame assembly
Ball loader (Nicknamed "The Hyneman", see http://www.youtube.com/watch?v=AjQhLI5mT_o):
PVC construction for easy replacement at competitions
Surprisingly resilient despite best efforts of the drive team in practice
Easily clears bumpers
Loads on the run at multiple speeds
Entire assembly can be replaced in 5 minutes or less
Extension length <20"
When fully retracted, compresses ball onto the robot for snug fit
Loader weight ~1.9 lbs
Final Robot Weight: ~75 lbs.
SPECIAL THANK YOU TO TEAMS 360 AND 3826!!
